Page 4 of 6
FirstFirst ... 2 3 4 5 6 LastLast
Results 91 to 120 of 167
  1. Thanks a lot guys.. Just one more little question. I could probably figure out how to reseize it, or set the PAR or DAR as You mentioned - but if my video plays and looks well, is it something I should worry about - or is it fine to ignore?
    I do use Handbrake as I have to convert the files to somewhat smaller size for storing. Unfortunetely, with the amounts of tapes I have and need to work through (About 6000), I just can't afford the necessary storing space to deal with files this big. Thankfully, with Handbrake and H264 encoder, there's not much quality drop, with about 1/10th the size.
  2. Hi again everyone,
    I hope perhaps You'll be kind enough to answer one more question from me. I've now digitised around 100 VHS tapes, using the same set-up. Hauppauge capture card, AmarecTV and Lagarith.
    After capturing lossless, I then convert the AVI file into MP4 on Handbrake, with H.264 codec and some basic settings (No deinterlacing or such). I'm overall very happy with the outcome, but I shared some of the files with a friend of mine who likes to convert those to classic DVDs and watch them on his TV.
    ...and here lies the problem. He told me that after converting the files to DVDs using PowerDirector 365, He experienced blurring in motion. He does not experience it with other people's captures which He often converts in such a manner.
    Could You perhaps guess what could be the issue here? Could the Lagarith codec be the problem, or perhaps my friend could alter the settings on his end in PowerDirector or similar to avoid those issues?
    I'll be thankful if You'll find time to reply.
    Mar 2008
    Originally Posted by Aro View Post
    Hi again everyone,
    It's possible Handbrake created videos marked as progressive instead of interlaced. If so, it could cause this problem.
    Either submit a sample or look at one of the file's details (specifically "scan type") in Mediainfo (text view)
  4. Hi,
    Thanks a lot for Your reply! Yes, on mediainfo, the MP4 file is listed as Progressive, under "scan type" category.
    Mar 2008
    Hi,
    When the file is accessed it's going to handled as if it were progressive.
    If the video content is actually interlaced, that's potentially a problem.
    It's possible the Lagarith source also was marked as progressive, but when encoding to the mp4 it can be handled with
    the proper (manual) intervention
  6. I don't have the Lagarith lossless AVI file at hand now, but I do have HuffYuv AVI capture-source and then MP4 conversion. Avi file is listed as interlaced, while mp4 file is listed as progressive. Probably safe guess it will be true for Lagarith as well?
    So was I doing something wrong with my handbrake settings?
    Also, do You know if my friend can do something to get around this issue while converting the files to DVDs, on his end - with the "flawed" mp4 files at hand?
    Thanks a lot, sir. I'd be very grateful if You could advice me on that front when You'll have some time.
    Mar 2008
    In DVD converter AVStoDVD, when the files are added to the project, you can right click on the files in the window,
    Edit source title info/Video scan type/Interlaced. This will yield an interlaced DVD (no problem)
    An alternative might be attempt a deinterlace at this stage, but some damage has already been done (see below)
    This should give an improvement, but see jagabo's reply when I asked about this myseff a number of years ago:
    https://forum.videohelp.com/threads/398436-In-VirtualDub-where-is-the-capture-BITRATE-...ng#post2592253
  8. Thanks a lot!
    First for Handbrake settings. I typed in ":interlaced=1:tff=1" in video advanced options. Now I get:
    Scan type : MBAFF
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Is this actually good?
    Also, would it be advisable - after reading Jagabo's reply on that topic - to set Encoder Profile as High422, which would keep the MP4 file in the 4:2:2?
    Thanks!
  9. Originally Posted by Aro View Post
    Thanks a lot!
    Scan type : MBAFF
    Yes. It's what's expected with x264 -- which only uses MBAFF for interlaced video (as opposed to PAFF)
    Not much outside a PC will play 4:2:2 encoded AVC. Stick with 4:2:0 if you want wide compatibility. Make sure the 4:2:2 to 4:2:0 conversion is done properly (interlaced mode).
    May 2005
    Australia-PAL Land
    I get the heebygeebies when I hear of Interlaced MP4s.
    If your friend's Power Director cannot accept Lagarith, I suggest you deinterlace with Handbrake and convert to MP4 and try that in Power Director.
    Oct 2018
    Town Spa Pizza, United States
    Powerdirector will ingest Lagarith, perhaps a codec installation is needed.
  12. Originally Posted by Alwyn View Post
    What's wrong with it? Interlaced is interlaced, and .mp4 is just a container. The problem is sometimes (too often?) that the conversion 4:2:2 -> 4:2:0 interlaced is done incorrectly (chroma mistreatment) - sometimes done badly by the tools. People often don't even notice the flaw though.
    Btw. there is a good chance that the TV player's deinterlacer is on par or even better than Handbrake's deinterlacing.
    Another problematic scenario is when progressive video is flagged as interlaced (for whatever reason) and the player is forced to deinterlace it.
    May 2005
    Australia-PAL Land
    It would appear PowerDirector doesn't like it. Perhaps because:
    Anyway, mine was only a suggestion. The idea is we try to solve the problem, not discuss theory.
    If it works, Aro can get some guidance on better deinterlacing.
  14. Thanks a lot for all the replies. I'll experiment with the options presented, communicate with my friend and let You know how it worked!
    You guys are the best.
  15. Originally Posted by Alwyn View Post
    Would You suggest using other format? Sorry for all the naive questions, I don't know much about it - I went with MP4 since it's common and I went with Handbrake since it was first free software which was recommended to me. I'd be happy switching if there's a better alternative format, method or software.
    I need to compress those big AVI files unfortunetely, since I just don't have the budget for that amount of space with the amount of tapes at hand...
    Problem with interlacing on Handbrake is - on my PC at least - it takes ages. Like 20 hours for 1.5 hours of video? That's a bit ... rough. I wanted to keep it as it is, so "interlaced", I had all the filters off. Had no idea that it was being changed (or not changed, just wrongly categorised as?) to progressive.
    In any case, big thanks again - I'll experiment with it, but in the meantime, if anyone thinks I should use different format, software, conversion method - please let me know!
  16. @Aro:
    mp4 is just fine. In case you don't get along with Handbrake, skip it and try the following:
    1) Unzip the attached Aro.zip to your desktop. You should now see the folder icon 'Aro' on your desktop
    2) Open that folder in explorer (double-click on it). You will now see 3 files in the explorer window: ffmpeg.exe, deinterlace_.cmd, interlaced_cmd.
    For interlaced encoding:
    3a) Drag and drop your .avi file (from wherever it is) onto the interlaced_.cmd -> The interlaced encoding will start automatically. Wait until it finishes.....
    For deinterlacing + progressive encoding:
    3b) Drag and drop your .avi file (from wherever it is) onto the deinterlace_.cmd -> The deinterlacing+encoding will start automatically. Wait until it finishes.....
    4) The compressed encoded .mp4 file will be in the same folder where you had your .avi
    (If it doesn't work upload a short snippet of your .avi)
  17. Big Thanks, I'll certainly give it a try also! As for Handbrake, it's not that I don't get along with it - it's pretty easy to use, I just want to final result to be ok.
    Oh and perhaps I'd have one more question - if I decide to stick with Handbrake. Should I fix the aspect ratio while converting the files? I wrote about it on the last page here a while ago. I get Aspect Ratio of either 5:4 for Pal or 3:2 for NTSC videos for the lossless capture AVI files with either Lagarith or HuffYuv. I didn't notice it being problematic, but since I'm trying to fix some things, maybe that would be wise change to make also?
    Sorry if I'm stretching Your patience here.
  18. Originally Posted by Aro View Post
    No problem, but a "Handbraker" may explain the 'Dimensions' Tab in Handbrake to you.
  19. Originally Posted by Sharc View Post
    Fair enough - just to be clear, I'm perfectly happy to do it on any tools that allows me to do it easily enough and effectively, just the way I read that last reply got me thinking You suggested it in case I have issues with Handbrake.
    I'll try out both for sure and thanks once again.
  20. Maybe someone will find time to take a look at it. It's mediainfo text data on two files, original AVI and the "final" mp4.
    Does everything look ok? (Thanks regardless).
    Original AVI file:
    Format : AVI
    Format settings : WaveFormatEx
    File size : 79.8 GiB
    Duration : 2 h 54 min
    Overall bit rate : 65.4 Mb/s
    Frame rate : 25.000 FPS
    Video
    Format : HuffYUV
    Format version : Version 2
    Codec ID : HFYU
    Bit rate : 61.3 Mb/s
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 5:4
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 8 bits
    Scan type : Interlaced
    Bits/(Pixel*Frame) : 5.911
    Stream size : 74.8 GiB (94%)
    Audio
    Format : PCM
    Format settings : Little / Signed
    Codec ID : 1
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 1.87 GiB (2%)
    Alignment : Aligned on interleaves
    MP4 File (Converted using Handbrake):
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/iso2/avc1/mp41)
    File size : 2.06 GiB
    Duration : 38 min 39 s
    Overall bit rate : 7 644 kb/s
    Encoded date : 2025-07-10 19:06:58 UTC
    Tagged date : 2025-07-10 19:06:58 UTC
    Writing application : HandBrake 1.9.2 2025022300
    Video
    Format : AVC
    Format profile : Main@L3
    Format settings : CABAC / 5 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 5 frames
    Codec ID : avc1
    Bit rate : 7 439 kb/s
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : MBAFF
    Bits/(Pixel*Frame) : 0.717
    Stream size : 2.01 GiB (97%)
    Writing library : x264 core 164 r3186 585e0199
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=tff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Color range : Limited
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Source duration : 38 min 39 s
    Bit rate : 198 kb/s
    Channel layout : L R
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 54.8 MiB (3%)
    Source stream size : 54.8 MiB (3%)
    Title : Stereo / Stereo
    Default : Yes
    Alternate group : 1
  21. Looks correct to me. It's interlaced 720x576i25, TFF, 4:2:0, DAR 4:3.
    A player/TV should have no issues with it and deinterlace it on the fly during playback.
  22. Originally Posted by Sharc View Post
    That's great to hear.
    Thanks for Your time over those 2 days, it's been extremaly helpful.
    Now I'll have to wait and see if my friend can make it work on his end. I'll keep You guys updated, perhaps You'll find this professionally interesting )?
  23. Originally Posted by Aro View Post
    That's because AVI doesn't really support aspect ratio flagging. Many programs will use the relative frame dimensions as the display aspect ratio. 720x576 = 5:4, 720x480 = 3:2. It's up to you to make sure post-capturing filtering and encoding is aware of the "display aspect ratio" or "sampling aspect ratio" (sometimes called pixel aspect ratio). The general equation between the three is:
    DAR = SAR * FAR
    where:
    DAR is the display aspect ratio, the final shape (width:height) of the displayed picture
    SAR is the sampling aspect ratio, the distance between samples horizontally:vertically
    FAR is the frame aspect ratio (pixels wide:pixels high)
    You may need to force the SAR or DAR in your software.
  24. Originally Posted by jagabo View Post
    [Attachment 87771 - Click to enlarge]
    Would that be a correct way of doing it?
    Thanks!
  25. Member
    May 2005
    Australia-PAL Land
    On the Video tab in the "Video Encoder" droplist, choose an option that uses any GPU on your system as opposed to straight "h264". On my laptop, if I use H264 (Intel QSV) I get 80fps encode speed. If I use "H264 (x264)" (ie using the CPU) I get only 6fps.
  26. Originally Posted by Alwyn View Post
    Would it not negatively affect the quality? I also have encoder preset set at slow, I guess I could move it to fast - but I had the same reservation about it.
  27. Member
    May 2005
    Australia-PAL Land
    Possibly, but life is short! I think you'll agree that 20 hours for 1.5 is not workable. Make one mistake and it's 20 hours back.
    Anyway, give them a test; try each encoder and the encoder presets and see if there's any difference. Theory is fine but when practicality achieves 95% of the quality and you're much more productive, the tradeoff may be worth it.
  28. Originally Posted by Alwyn View Post
    Ha! That's a good point.
    Although, You know - turns out Yadiff-Bob is actually pretty fast, very doable. I've been using Decomb->EEDI2BOB before and that's painfully slow in comparision. Even if it's better, yes life's too short I agree )!
    I think I will have to deinterlace it anyway if I continue using Handbrake. Keeping files interlaced through advanced options on Handbrake is problematic, turns out on many videos I get the same blurry picture that my friend has been complaining about.
  29. Originally Posted by Aro View Post
    Interlaced is not "problematic" as such. Interlaced video has to be properly deinterlaced by the player during playback (unless your monitor is a legacy CRT). If it is not getting deinterlaced you may obtain what you (or your friend) describe as "blurry". Also, the player should preferably be set for "double rate" ("2x" or similar) rather than "base rate" deinterlacing. The quality one eventually gets depends on the deinterlacer of the player.
    If you deinterlace your captures before encoding and encode progressive, a high-quality deinterlacer (like QTGMC) usually eats up much more CPU power than the progressive encoding, hence slowing the overall process significantly down - unless your graphic card supports decent HW deinterlacing as well.
  30. Originally Posted by Sharc View Post
    Thanks for the technical explanation. I think I kind of get a gist of it, although obviously not completely ).
    I think there could be some issue with enforcing keeping the files interlaced through advanced settings on Handbrake. Many of convertions fail after I put those "commands" in the advanced box and while some look good, other look strange - in motion.
    Here is a sample:
    https://mega.nz/file/CVx3mIxA#m5SvcISdy0kJ6deJQp9E-tEPQTsGORLh3k2kEYgxfIE
    Although what's interesting is that when I play it on the Mega without downloading, it looks perfectly fine - only on my computer it blurrs... so it's perhaps VLC player (in my case) sort of reading it wrong in terms of it being interlaced? (Sorry for the confusing nature of my description, but I just don't have the proper understanding of how it all works).
    Will try out Your software option next.
