I use Subtitle Edit and save subtitles as Advanced Sub Station Alpha(.ass). I save a subtitle with a minimum 83 millisecond gap between lines. The next time I open it the gap goes to 80 millisecond. Just to be sure I change to 83ms gap again and save but when opening it still reverts to 80ms. Has anybody seen this happen with their Advanced Sub Station Alpha subtitles. One more thing is if I save the file SubRip(.srt) the gaps are maintained when reopening the file. Anyone else have this happen when working with Subtitle Edit? Any info with this would be appreciated.
PAL frame rate? At 25 fps each frame is displayed for 40 ms. So everything works in 40 ms increments.
Mine is NTSC frame rate. Video fps 23.976. Subtitle Edit shows 2 frame gap equal 83 ms. I have gap set for 83 ms save but when reopened gap reverts to 80 ms Thanks for reply. Would appreciate any more info you have. GregT
Same behaviour here. Gaps initially set to minimum 42ms, they are changed to 40ms when reopen the ASS.
I am doubting whether this is a bug or proper behaviour for ASS format. -
I saw this:
https://www.md-subs.com/blog/line-spacing-in-ssa
So the timing within ASS is always in hundredths of a second, ie, two decimal places. So 83 milliseconds (0.083) becomes 80, milliseconds (0.08). 42 milliseconds (0.042) becomes 40 milliseconds (0.04).A note of caution
The ASS format has a whole host of problems, which is why it’s not standardized in the industry. Most importantly, its timing format uses centiseconds rather than frames or milliseconds, so when you import from or export to ASS, the round-off errors will sometimes push your timecodes over to the adjacent frame, spoiling your minimum intervals, shot change gaps, durations, etc. This can be avoided if you work around it carefully, but, unless you know exactly what you’re doing, it’s better to use something else for certain projects. -
Thanks for the explanation. I did not know ass/ssa files deal in centiseconds. This makes sense to me. I thought I was doing something wrong. Maybe in the future ass/ssa files can be formatted to work with milliseconds. Again thanks for the info. GregT
If you look at the basic format of subtitle lines in SSA files (a line stolen from a random SSA file);
You'll see that there are only two decimal places. If you extended that to three decimal places (or a variable number up to the following comma) many renderer's parsers will probably have to be modified as well as the editors. I doubt this will happen any time soon.Code:Dialogue: 0,0:00:17.95,0:00:20.79,Credits ENG,,0,0,0,,{\blur0.6\c&HF9EBEE&\fscx61.017\fscy76\pos(100.607,70.222)}Planning
subtitle edit is auto breaking lines
By cocowash in forum SubtitleReplies: 2Last Post: 8th Dec 2024, 15:33 -
Subtitle Edit - Shortcut to set a subtitle minimum gap
By tren in forum SubtitleReplies: 2Last Post: 1st Aug 2023, 06:44 -
To delete empty lines and lines with music symbols in subtitle edit at once
By Pusat in forum SubtitleReplies: 2Last Post: 9th May 2023, 11:20 -
Subtitle Edit manual spacing of lines
By loninappleton in forum SubtitleReplies: 14Last Post: 11th Sep 2022, 18:40 -
Is there a way i can re-time all the lines in a subtitle file at once?
By Unknown01 in forum Newbie / General discussionsReplies: 5Last Post: 10th Apr 2020, 11:35
