Results 1 to 19 of 19
  1. Is it possible to pull (at a minimum, the creation date) out of a MOV file and generate an SRT from that?
    I'm working on replacing my trusty 1080p camcorder with an iPhone 16. One of the things I like about the camcorder, it embeds the date/time into the AVCHD MPEG files. And when I'm playing the video back, if I turn on sub-titles, I can see the date/time the video was created on the screen.
    If this is possible, I can convert my MOV files to MKV and attach an SRT file that has the date/time from the original MOV file and I'm good to go.
    Apr 2007
    Australia
    Assuming Windows x64. (Helps forum members if you edit your profile to include your OS. Ta.)
    Needs the path to your copy of the command line version of MediaInfo.exe.
    https://mediaarea.net/download/binary/mediainfo/24.12/MediaInfo_CLI_24.12_Windows_x64.zip
    @echo off
    set mediainfo=C:\VidAud\MediaInfoCLI\MediaInfo.exe
    for %%a in (*.mov) do "%mediainfo%" "--Output=General;%%Encoded_Date%%" "%%a" > "%%~na.srt"
     pause
    I have a grand total of 1 MOV file on my pc. Very little testing.
    Instead of Encoded_Date, other options you might try:
    Recorded_Date
    Tagged_Date
    Written_Date
    Mastered_Date
    File_Created_Date
    Cheers.
  3. Originally Posted by pcspeak View Post
    @echo off
     pause
    Recorded_Date
    Tagged_Date
    Written_Date
    Mastered_Date
    File_Created_Date
    Cheers.
    I updated my computer details
    I created a bat file with that and it produced a SRT file and it -did- give me the meta data....
    2024-12-25 18:30:06 UTC
    ... but what I'm really after is, when this mythical tool I'm looking for examines the MOV file, it will build me an SRT like this:
    00:00:00,000 --> 00:00:01,024
    December 25, 2024 1:00pm
    2
    00:00:01,024 --> 00:00:02,048
    December 25, 2024 1:01pm
    3
    00:00:02,048 --> 00:00:03,072
    December 25, 2024 1:03pm
    4
    00:00:03,072 --> 00:00:04,096
    December 25, 2024 1:04pm
    ... ignore the time stamps but this is just to give you a rough idea of what I'm after. Every MOV file I feed into whatever I'm looking for, it needs to take the date/time stamp (or at least the date stamp) from the embedded meta info in the MOV file and generate a SRT file with that info.
    I recorded my kids opening their gifts on Christmas this year so I thought I'd be smart and created a single entry for a SRT file that was basically like this:
    00:00:00,000 --> 01:03:07,445
    Christmas 2024
    ... I was playing it back and it was fine. I turned the subtitles on and saw 'Christmas 2024' on the screen and thought I was good to go. But I turned off the subs and turned them back on but the 'Christmas 2024' didn't come back. So I need multiple lines to put the subs back on the screen when requested.
    Having a program rip through a MOV file and auto-generate those lines based off the date/time stamp from the MOV meta data is the goal.
  4. try this. Works for windows with seq, grep, sed, awk and mediainfo. All available for free on the internet. (Google is your friend)
    You will need to set up your file path.
    set "file_path=C:\xxxxxxxxxx\test01.mp4" ... line 2
    program is set up for mp4 file. If mov is used then change line 3 to
    for /f "tokens=*" %%e in (' dir %file_path% ^| awk "BEGIN{FS=\" \"} /mov/ {print $5,$1,$2,$3}"') do set "Event_Info=%%e"
    Program will output the srt file in this template
    1
    00:00:00 --> 00:00:05
    test01.mp4 10/24/2024 08:51 PM
    2
    00:00:05 --> 00:00:10
    3
    00:00:10 --> 00:00:15
    The srt time refresh is every 5 seconds.
    Program has been thoroughly debugged, hence if it does not work then the challenge lies with you.
    @echo off
    for /f "tokens=*" %%e in (' echo %file_path%  ^| sed -e "s#mp4#srt#"  ') do set  "srt_path=%%e"
    for /f "tokens=*" %%e in (' dir %file_path% ^| awk "BEGIN{FS=\" \"} /mp4/ {print $5,$1,$2,$3}"') do set  "Event_Info=%%e"
    for /f "tokens=*" %%e in (' mediainfo %file_path% ^| grep "Duration" ^| awk "BEGIN{FS=\" \"} NR==1 {print int((($3*60+$5)*12)+0)}" ') do set  "Event_Count=%%e"
    seq 1 %Event_Count% | awk "BEGIN{hh1=0;mm1=0;ss1=0;x=0; \" echo %Event_Info%\" | getline EvInfo;} { x++; ss2=ss1; mm2=mm1; hh2=hh1; ss1=ss1+5; if (ss1 > 59) mm1=mm1+1;if (ss1 > 59) ss1=ss1-60; if (mm1 > 59) hh1=hh1+1;if (mm1 > 59) mm1=mm1-60; hh1 <10? phh1=\"0\"hh1 : phh1=hh1; hh2 <10? phh2=\"0\"hh2 : phh2=hh2; mm1 <10? pmm1=\"0\"mm1 : pmm1=mm1; mm2 <10? pmm2=\"0\"mm2 : pmm2=mm2; ss1 <10? pss1=\"0\"ss1 : pss1=ss1; ss2 <10? pss2=\"0\"ss2 : pss2=ss2; print x; print phh2\"\072\"pmm2\"\072\"pss2 \" --\076 \"phh1\"\072\"pmm1\"\072\"pss1; print EvInfo\"\n\"  } " > %srt_path%
    echo+
    echo Program Complete
    echo+
  5. Originally Posted by jack_666 View Post
    I Googled up those programs and tried installing them in Windows but when I ran my batch file, it complained that it couldn't find any of them. I looked at my drive and don't see the binaries.
    I guess I stink at this?
    BUT, I have WSL installed in Windows and I also have a Linux box if need be and all of those individual commands worked in both places when I typed them out. Now, I just need a batch file (that is Linux friendly) to bring it all together. Would you happen to have that? When I tried, it freaked out and threw errors about \r this and \blah that.
    I'll try to figure it out tomorrow......nearly midnight and I'm exhausted.
    Apr 2007
    Australia
    A batch file.
    MediaInfo, ffprobe and a lot of other programs rely on the meta-data in a file.
    I usually delete 99.99% of meta-data, so this makes it hard to test.
    The batch file works on a sample MOV video I downloaded.
    I also ran it against a couple of MP4 videos. That worked, too.
    The batch file should handle MOV, MP4 and MKV files.
    Obviously this will depend on what meta-data is available to MediaInfo.exe.
    meta2subs01.bat
    @echo off
    set counter=0
    :start
    for %%a in (*.mp4, *.mkv, *.mov) do call :process "%%a"
    goto :end
    :process
    if exist "%~n1.srt" del /q "%~n1.srt"
    set video=%~1
    :: Set the Encoded_Date variable. Set the clock variables c_hours, c_mins.
    "%mediainfo%" "--Output=General;%%Encoded_Date%%" "%video%" > "%~n1-clock.txt"
    setlocal enabledelayedexpansion
    for /F "usebackq tokens=1-5 delims=^:^ " %%a in ("%~n1-clock.txt") do (
        set Encoded_Date=%%a
        set c_hours=%%b
        set c_mins=%%c
    :: Set the video duration in milliseconds
    "%mediainfo%" "--Output=General;%%Duration%%" "%video%" > "%~n1-duration.txt"
    set /p duration= < "%~n1-duration.txt"
    ::set the subs variables in_hours:in_mins:in_secs --^> out_hours:out_mins:out_secs.
        set in_hours=00
        set in_mins=0
        set in_secs=00,000
        set out_hours=00
        set out_mins=1
        set out_secs=00,000
    :update-srt
    if not %duration% gtr 0 goto :eof
    set /a duration=%duration%-60000
    if not %c_mins% gtr 59 set /a c_mins=%c_mins%+1
    if %c_mins% gtr 59     set c_mins=0 && set set /a c_hours=%c_hours%+1
    set /a counter=%counter%+1
    echo %counter% >> "%~n1.srt"
    set subs_input=%in_hours%:%in_mins%:%in_secs%
    set subs_output=%out_hours%:%out_mins%:%out_secs%
    echo %subs_input% --^> %subs_output% >> "%~n1.srt"
    if not %in_mins% gtr 59 set /a in_mins=%in_mins%+1
    if %in_mins% gtr 59 set in_mins=00 && set /a in_hours=%out_hours%+1
    set subs_input=%out_hours%:%out_mins%:%out_secs%
    if not %out_mins% gtr 59 set /a out_mins=%out_mins%+1
    if %out_mins% gtr 59 set out_mins=00 && set /a out_hours=%out_hours%+1
    echo %~n1 - %c_hours%:%c_mins% >> "%~n1.srt"
    echo. >> "%~n1.srt"
    goto :update-srt
    :end
    del *.txt
      pause
    You should get something that looks like this, showing the name of the video file, it's encoded time and the sub updated each minute. Times are UTC, so no am/pm.
    1
    00:0:00,000 --> 00:1:00,000
    Christmas 2024 - 10:48
    2
    00:1:00,000 --> 00:2:00,000
    Christmas 2024 - 10:49
    3
    00:2:00,000 --> 00:3:00,000
    Christmas 2024 - 10:50
    4
    00:3:00,000 --> 00:4:00,000
    Christmas 2024 - 10:51
    At this point anything better than a 50% success rate should be classed as a success.
    Cheers. (I now have a slight headache. And I too, am tired. )
    p.s. I'm not sure what will happen when the video is more than an hour long. I had nothing to test with.
    I hope the in_hours and out_hours fields get incremented.
    Last edited by pcspeak; 29th Dec 2024 at 03:22. Reason: Improve my explanation. It was bleah!
  7. Originally Posted by jack_666 View Post
    1
    2
    3
    @echo off
    echo+
    echo+
    I'm having a hard time looking for seq. I can only find something called SEQ by a company called DataLust.
  8. Originally Posted by pcspeak View Post
    ... snip
    First, let me thank you and subscript2 for your help!
    Sadly, something seems amiss with you bat file. I tried it on a 3 minute MOV file and imported the SRT it created into Subtitle Edit and get this:
    [Attachment 84463 - Click to enlarge]
    ... the resulting SRT file has each entry lasting for an hour:
    IMG_8229 - 18:31
    2
    IMG_8229 - 18:32
    3
    IMG_8229 - 18:33
    4
    IMG_8229 - 18:34
    ... maybe this can help simplify things. I can live without the timestamp but the date is critical. Can you adjust it so only the "Encoded Date" is extracted and populated into the SRT file?
    Apr 2007
    Australia
    Interesting. Your post of the srt file above shows nothing in the hours field. I know the minutes field only shows a single number and not the preceding zero, as it also does here. The srt still displays correctly here. I'll look into having just the Encoded_Date displayed.
    YES, it does make things easier.
    Cheers.
  10. Did you play through the file to verify? It's working on my end. The subtitles changes every minute. My Subtitle Edit looks like yours and when I click on a line it says the duration is 60s.
    As for the date all you'll have to do is change line 54 (7th to last line) to:
    echo %Encoded_Date% - %c_hours%:%c_mins% >> "%~n1.srt"
    So far the only issue I'm having is that my video's timestamp are in UTC and not local time so I'll need to learn to convert that.
    Apr 2007
    Australia
    As Subscript2 says, except:
     echo %~n1 %Encoded_Date% - %c_hours%:%c_mins% >> "%~n1.srt"
    To include the video file name.
    @Subscript2. Thanks for testing. Much appreciated. Cheers.
  12. @pcspeak and @Subscript2 Thank you both so very much!!!
    Ignore my comment about the 1 hour length, I was wrong.
    I edited the 54th line and it now does just the date and it's working perfectly, exactly what I was looking for!
    Hmmmm, I wonder if the author of Subtitle Edit could bake this functionality into that tool? Have it auto-generate an SRT file based off of user select-able metadata fields it pulls from MOV files and at an interval you pick?
    .... eh, in the mean time, this batch file will do the job!
  13. Updated to script to display an extra 0 for the minutes when it's less than 10
    Added a conversion from UTC to the PC's timezone with AM/PM
    Changed date from YYYY-MM-DD to e.g. Sunday, December 29, 2024
    @echo off
    set counter=0
    :start
    goto :end
    :process
    set video=%~1
    %mediainfo% "--Output=General;%%Encoded_Date%%" "%video%" > "%~n1-clock.txt"
        set c_hours=%%b
        set c_mins=%%c
        set c_secs=%%d
        set Date_Time=%%aT%%b:%%c:%%d+0
    powershell Get-Date "%Date_Time%" > "%~n1-localTime.txt"
    for /F "usebackq tokens=1-8 delims=^:^,^-^ " %%a in ("%~n1-localTime.txt") do (
        set c_DayofWeek=%%a
        set c_Month=%%b
        set c_Day=%%c
        set c_Year=%%d
        set c_hours=%%e
        set c_mins=%%f
        set c_sec=%%g
        set c_AMPM=%%h
        set c_Date=%%a, %%b %%c, %%d
    %mediainfo% "--Output=General;%%Duration%%" "%video%" > "%~n1-duration.txt"
        set in_hours=00
        set in_mins=0
        set in_secs=00,000
        set out_hours=00
        set out_mins=1
        set out_secs=00,000
    :update-srt
    if %in_mins% gtr 59 set in_mins=00&& set /a in_hours=%out_hours%+1
    if %out_mins% gtr 59 set out_mins=00&& set /a out_hours=%out_hours%+1
    if %c_mins% lss 10 echo %c_Date% - %c_hours%:0%c_mins%%c_AMPM% >> "%~n1.srt"
    if not %c_mins% lss 10 echo %c_Date% - %c_hours%:%c_mins%%c_AMPM% >> "%~n1.srt"
    echo. >> "%~n1.srt"
    goto :update-srt
    :end
    del *.txt
    Thanks @pcspeak. I've been wanting to do this for quite awhile and your script really gave my a push into the right direction.
    Apr 2007
    Australia
    @Subscript2
    EXCELLENT! Your additions to the batch file are very well done.
    Sorry for the delay in responding. Life got in the way.
    I must spend more time learning about PowerShell.
  15. Originally Posted by Subscript2 View Post
    Thank you both for the amazing job on this!
  16. @Subscript2
    Sorry to necro this thread but as I use your amazing bat file more and more, I was wondering if you could make another change?
    Every now and then, I have to extract the date/time from LOTS of .mov files and then, mash all those .mov files into a single file. The problem I'm having is combining all the SRT files into a single file and marrying it with the mashed together .mov file.
    Along with creating individual SRT files from multiple .mov files, could your bat file be updated to create a single SRT file that is generated from all those individual ones?
    Hope I'm explaining that correctly.
    Apr 2007
    Australia
    If you are always going to display the subs then the most simple way would be to hard code the subs into the videos and then 'mash' them into a single file.
  18. Originally Posted by pcspeak View Post
    That's the sticky part.... I want to default to having the subs off and let the user decide if they want them on.
  19. Originally Posted by Subscript2 View Post
    Thanks, it was very useful
