Results 1 to 17 of 17
  1. I need help to download a video from vtm i'm new here this is the link https://www.vtmgo.be/vtmgo/afspelen/dfa17b4b-a2dc-43e0-8468-e798f7855402
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    N_m3u8DL-RE "https://video.dpgmedia.net/out/v1/f02ff2acda974d0599ecb82d2944029f/eb76c933215848938246f10a6161dc4b/75aa63df75e944e0aeafbdbcbf096fc1/index.mpd?aws.manifestfilter=subtitle_language%3Azzz%3Btrickplay_type%3Anone%3Baudio_codec%3AAACL" --key d19304ec49cb33808654891c67495577:f2bac531c6fffd6d3fe33a6c2aa7446a --key 5f90dbc419753cbca060192af5965189:9cf1cdfd7164d4b29f213ccba992193e --key 2fbacb26fb893047aab1be199138f728:0448a8b2bc56758ac2bd5886ec8be899 --key 8e2917d99efe36f8a4701217e34c8a52:fc52e124697eae5f77eca3a57f834db4 --key f80e69481edf4044a6affb2428cbe157:f16206030bfbfee30b4a113aeef5835f --key af097008a9ef36efae7da272f8955727:7e0fa7b5363b7ca4e8a6886245e86ac6 --key b0bcbf6324b538a6b9c8922544867d6c:6d40ccb34139bf69375dce6b7d9ed317 --save-dir "media\vtmgo_be" --save-name "Single_Bells_Aflevering_12" -M format=mkv
  3. thanks but what do i need to do with that like i said i'm new here is there is there a simple guide i need to use or so please help
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Install and place in the same folder (any folder of your choice) the following programs:
    - N_m3u8DL-RE
    - ffmpeg
    - mp4decrypt
    Then open cmd in that folder and run the previous command
  5. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Go in the ffmpeg and bento folder and look for ffmpeg.exe and mp4decrypt.exe (look for folder in folder if needed) and place them near N_m3u8DL-RE exe that you already have. Then open CMD not powershell. Or if you prefer powershell append .\ to the beginning of the command
  6. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    No idea. Try to run the command without save-dir and save-name parameters
    N_m3u8DL-RE "https://video.dpgmedia.net/out/v1/f02ff2acda974d0599ecb82d2944029f/eb76c933215848938246f10a6161dc4b/75aa63df75e944e0aeafbdbcbf096fc1/index.mpd?aws.manifestfilter=subtitle_language%3Azzz%3Btrickplay_type%3Anone%3Baudio_codec%3AAACL" --key d19304ec49cb33808654891c67495577:f2bac531c6fffd6d3fe33a6c2aa7446a --key 5f90dbc419753cbca060192af5965189:9cf1cdfd7164d4b29f213ccba992193e --key 2fbacb26fb893047aab1be199138f728:0448a8b2bc56758ac2bd5886ec8be899 --key 8e2917d99efe36f8a4701217e34c8a52:fc52e124697eae5f77eca3a57f834db4 --key f80e69481edf4044a6affb2428cbe157:f16206030bfbfee30b4a113aeef5835f --key af097008a9ef36efae7da272f8955727:7e0fa7b5363b7ca4e8a6886245e86ac6 --key b0bcbf6324b538a6b9c8922544867d6c:6d40ccb34139bf69375dce6b7d9ed317 -M format=mkv
    If it still fails, try opening cmd with admin privileges, then cd into your folder and then run the command
  7. thanks but unfortunately it still doesn't work it's always the video is broken and no sound the folder is on my desktop so it always stops working when he starts the audio
  8. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
  9. I'm really thankful but do you have any idea what the problem was so i can maybe do it in the future and how did you actually get the code
  10. Ensure that the folder you’re trying to access has the correct permissions. Right-click on the folder, select “Properties,” and navigate to the “Security” tab to verify permissions.
  11. do you maybe have other ideas what the problem may be is it maybe my laptop settings the only think i did is create the folder i downloaded the content in the folder and open cmd as admin sorry that i maybe waisting your time
    https://forum.videohelp.com/attachment.php?attachmentid=84333&stc=1&d=1735209575
Name:	Screenshot 2024-12-26 113922.png
  12. Yes don't know
    you can try to create another folder ....for example in C:\
  13. tried that already i also turrned my protection off it still doesn't work
