I have ripped a dvd and converted it to svcd with two audio languages (Using smartripper,dvdtoavi and TMPGenc). But when i come to burning it, i am forced into turning of standard compliance and i am unable to take advantage of the 10 or so percentage of extra video you can get by using nero. I.e. My 800mb mpeg2 does not fit on a 70min cd. IS THERE ANYWAY I CAN CHANGE THE OPTIONS IN NERO OR HOW I ENCODE THE FILM IN ORDER TO FIX THIS PROBLEM????????????
Thanx in advance for your help!!
Just turn off standard compliance and burn the thing. If your player plays it, theres nothing to loose sleep over.
Nero is especially picky on standard compliance with SVCDs. You must have a program stream with video 480x480 25fps or 29.976fps (incl. 23.976 with 3:2 pulldown flags), audio 44.1kHz on all of your audio tracks ... otherwise it will tell you your file is not compliant.
Again, just turn off standard compliance, burn the disc and get on with your life.
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 02:56 -
How do I burn multiple subtitle tracks to a DVD with ffmpegx
By wildgeese in forum ffmpegX general discussionReplies: 6Last Post: 26th Feb 2009, 12:54 -
How to burn a mkv file to dvd with dual audio and subtitles with nero.
By drkcloud in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2008, 04:48 -
Nero Help with Data Tracks
By KnucklesNilan in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 11:06
