I used to be fine with DVD Architect but now I can't find it anymore. Is it still supported or does it no longer exist?
they stopped selling it at least 4 years ago.
Are you wanting to purchase it or do you have a serial and need to reinstall it?
I have the serial number but I wanted to know if it is still supported and if there are updates before reinstalling it
It's no longer supported. You can download the last version (version 7) from Magix if you provide the serial number.
https://www.magix.com/int/support/my-service-center/product-downloads/ -
I have version 7, but since it is very dated and does not load some types of files such as mkv I do not need it. Too bad it is no longer updated. Thanks anyway.
Then you can switch to Magix Studio Suite.
Thanks to Alwyn's reminder, it can create Blu-Rays, customizes menu, and software accepts mkv.
And you can give yourself a Christmas present, it is on on HumbleBundle, it is for $30 now and together with full Vegas Edit Pro version for $35.
That is where I checked that Magix Studio Suite from. Offer will be available for at least two weeks or so.
DVD Architect ISO Building Error
By DarianG in forum Authoring (Blu-ray)Replies: 10Last Post: 2nd Oct 2023, 15:03 -
Button to navigate in menu of DVD Architect Pro 5.2
By younso in forum Authoring (DVD)Replies: 1Last Post: 17th Jul 2023, 10:58 -
set start item DVD Architect Pro 5.2
By younso in forum Authoring (Blu-ray)Replies: 1Last Post: 3rd Jul 2020, 19:52 -
DVD Architect question about menus
By Dig in forum Authoring (DVD)Replies: 3Last Post: 21st Apr 2020, 18:43 -
How to animate highlights on Dvd Architect or A. Encore?
By Sunshining in forum User guidesReplies: 7Last Post: 25th Mar 2020, 15:14
