  1. Good morning.
    I have another problem. I can't set a filter on MPD from this URL.
    I was able to get the key using Widevine L3 Decrypter though.
    URL: https://www.disneyplus.com/de-de/play/ebfc8e47-7e5c-404d-84b3-b6681284b1bf
    I know it's Disneyplus. Can you still make an exception? I wanted to download a Queen concert and watch it with a good friend.
    Best regards
    Heiko
  2. disney can't use mpd but m3u8
    tip: try with stream detector ext and set copy stream url as yt-dlp or N_m3u8DL-RE (and add key)
  3. Hi.
    Thank you. Stream Detector in Firefox does not recognize URLs in the concert.
    If I then set the m3u8 filter in the Firefox network tab, I get m3u8 addresses. If I download with N_m3u8DL-RE, I only get the sound in the video and no picture.
    Best regards
    Heiko
  4. I'm sorry, but now it worked with yt-dlp. I don't know why it didn't work before.
    But I noticed that when I download I get 2 files, but the audio file is not encrypted. I can play it like that. Is that normal?
    I always used mp4decrypt for both files.
