This is the readme file from eac3to
I have this aliasCode:Examples: eac3to blurayMovieFolder[lists disk titles] eac3to UHDMovieFolder 3)[lists details of title 3] eac3to UHDMovieFolder 3) -demux [demuxes all stream of title 3]I can run this to get the same output as on WindowsCode:alias eac3to='WINEPREFIX=~/wine32 wine /home/user/Downloads/eac3to_3.52/eac3to.exe'So the first command works fine, but the second and 3rd, don't.Code:eac3to /path/to/disc/root
I tried
How does one run any of these commands through Wine?Code:eac3to /path/to/disc/root 1) - bash: syntax error near unexpected token `)' eac3to "/path/to/disc/root 1)" - Please specify the source and dest files first and then the options. eac3to /path/to/disc/root -demux - Please specify the source and dest files first and then the options.
No matter what I try says "Please specify the source and dest files first and then the options.", where on my Windows machine all commands from the readme work fine.
see if this thread will help - https://forum.videohelp.com/threads/416320-Any-way-to-use-eac3to-exe-with-Wine
I would like to demux all tracks from title 1), which as to the readme would beCode:
$ eac3to /media/user/disk 1) 00002.mpls, 00000.m2ts, 1:44:18 - Chapters, 13 chapters - h265/HEVC, 2160p24/1.001 (16:9), HDR10, BT.2020 - h265/HEVC, 1080p24/1.001 (16:9), Dolby Vision, BT.2020 - DTS Master Audio, English, multi-channel, 48kHz - DTS Master Audio, English, stereo, 48kHz
I tried and same errorCode:eac3to /media/user/disk 1)
But from what I've read 1: notation is for tracks, not for titles/playlists.Code:eac3to "/media/user/disk" 1:/media/user/output/path -demux
// Found the solution
Originally Posted by Lithium9should be translated toCode:eac3to "/path/to/disc" "1)"
orCode:eac3to "Z:\path\to\disc" "1)"
Code:eac3to "$(winepath -w /path/to/disc 2>/dev/null)" "1)"
Any way to use eac3to.exe with Wine?
By beerninja in forum LinuxReplies: 5Last Post: 25th Oct 2024, 14:29 -
eac3to decoder pack
By Laflame in forum Blu-ray RippingReplies: 0Last Post: 8th Apr 2024, 18:10 -
Does DVDFab run on Linux/Wine? Experiences?
By Michael24 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jan 2024, 19:23 -
trim an ac3 with eac3to
By maudit in forum AudioReplies: 0Last Post: 26th Jan 2022, 16:42 -
[LINUX] can ffmpeg (or any othe linux command) genere an ANIMATED waveform
By Jintor_Universe in forum ProgrammingReplies: 5Last Post: 28th Oct 2021, 19:29
