I'm using yt-dlp to download a video from PBS. It has worked but I am left with one irritating issue.
I can locate the URL of the video stream by right-clicking on 'Inspect' when the stream is playing and then locating the URL in the 'Elements' section of Dev Tools. I then get the download going with yt-dlp. The video comes down fine (but without sound) and then the audio is downloaded. And this is where the issue is. The file that downloads is an Audio Described mp4 audio file, even if I do not have AD selected in the player.
The download URL appears twice in Dev Tools that I can see and, as an experiment, I have tried downloading with each. But the result is the same - AD audio. I am not seeing any way in Dev Tools to pair the 'standard' version of audio file with the video - the download just seems to default to AD audio.
Wondering if anyone else has come across this issue and found a solution?
Results 1 to 12 of 12
Video URL?
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Yes, it's a video URL. I can see options for a 1080p version and a 720p version in Dev Tools. And I select the 1080p version. Looked hard for an audio URL as well but could not spot anything.
I meant, what's the site page URL you're attempting to download from?
Cheers
The URL for the original stream on the site is https://www.pbs.org/video/doctor-and-detective-r19tjr/. Then, from Dev Tools, the download URL I used was https://urs.pbs.org/redirect/4e76c1fc35154bdb87ffdee08b063c97/\ , which produced the video download and a separate AD audio file in mp4 format. These I can readily combine once I'm happy with the audio.
If I can get this to work, I'm also wanting to download Episode 2 - original stream URL https://www.pbs.org/video/fact-and-fiction-fhjjae/. -
For https://www.pbs.org/video/doctor-and-detective-r19tjr/ you need american IP to watch the content, but you can download without needing a VPN in order to not waste data. Filter for m3u8 and get the first m3u8 URL that appears. You can then turn off VPN/proxy. Then run
So in order to download video 1080p with audio english non-ad, runCode:yt-dlp -F https://ga.pbs-video.pbs.org/videos/lucy-worsleys-holmes-vs-doyle/4c27e056-4c72-4cb2-8e9c-d383881488b3/2000455136/hd-16x9-mezzanine-1080p/lwhd0101-AABR-AVC_335.m3u8 [generic] Extracting URL: https://ga.pbs-video.pbs.org/videos/lucy-worsleys-holmes-vs-doyle/4c27e056-4c72-4cb2-8e9c-d383881...01-AABR-AVC_335.m3u8 [generic] lwhd0101-AABR-AVC_335: Downloading webpage [generic] lwhd0101-AABR-AVC_335: Downloading m3u8 information [generic] lwhd0101-AABR-AVC_335: Checking m3u8 live status [info] Available formats for lwhd0101-AABR-AVC_335: ID EXT RESOLUTION FPS │ FILESIZE TBR PROTO │ VCODEC VBR ACODEC MORE INFO ──────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────── multiple_audio_tracks-English mp4 audio only │ m3u8 │ audio only unknown [eng] English multiple_audio_tracks-English_AD mp4 audio only │ m3u8 │ audio only unknown [eng] English AD 375 mp4 768x432 30 │ ~143.49MiB 376k m3u8 │ avc1.64001e 376k video only 662 mp4 960x540 30 │ ~252.70MiB 662k m3u8 │ avc1.64001f 662k video only 1167 mp4 1280x720 30 │ ~445.53MiB 1167k m3u8 │ avc1.64001f 1167k video only 1756 mp4 1600x900 30 │ ~670.48MiB 1757k m3u8 │ avc1.640028 1757k video only 3062 mp4 1920x1080 30 │ ~ 1.14GiB 3063k m3u8 │ avc1.640028 3063k video only
Same steps for https://www.pbs.org/video/fact-and-fiction-fhjjae/ or any other video regardless of site.Code:yt-dlp -f 3062+multiple_audio_tracks-English https://ga.pbs-video.pbs.org/videos/lucy-worsleys-holmes-vs-doyle/4c27e056-4c72-4cb2-8e9c-d383881488b3/2000455136/hd-16x9-mezzanine-1080p/lwhd0101-AABR-AVC_335.m3u8
Thanks very much for your help, that worked perfectly! I want to have a go now at the second video - and sorry for the newbie question:
I can successfully replicate all the steps you set out in your post except the very first one.
You say 'Filter for m3u8 and get the first m3u8 URL that appears.' But I'm not sure I'm filtering in the right place to get the needed m3u8 file. I right click on the file stream, select Inspect and that takes me to DevTools (I'm using Edge). When I then filter in Elements, the first m3u8 file that appears is https://livestream.pbskids.org/out/v1/1e3d77b418ad4a819b3f4c80ac0373b5/est.m3u8\ which doesn't seem right.
I think I must be filtering for meu8 in the wrong place?
Thanks again. -
Filter in the "network" tab. When you applied the filter, refresh the page tab to make sure you get all requests from scratch.
Can I ask a quick follow up question. I now have both video and audio files working perfectly. If I wanted to include an English-language subtitle (caption?) with the video, is there a way with an amended or separate code to have yt-dlp bring everything together - video, audio and subtitle?
The alternative is to manually locate the subtitle file, and mux it with the mp4 file produced by yt-dlp in mkvtoolnix - which I can readily do. But I just wondered if it was possible to bring everything together within yt-dlp?
And I have both .vtt and .srt files - is one preferable to the other within yt-dlp? -
If the vtt/srt is in the m3u8 tracks, yes. If not, then mux manually with mkvtoolnix. Vtt and srt are both supported by yt-dlp
Cheers. I'll take a close look at the various m3u8 tracks to see if a vtt/srt is there.
Changing Default Audio Track & Removing Unwanted
By AVEd in forum Newbie / General discussionsReplies: 7Last Post: 8th Nov 2023, 13:13 -
Download Helping for an audio File
By ghostrewel in forum Video Streaming DownloadingReplies: 3Last Post: 25th Mar 2023, 12:12 -
How to download an .ism(?) file
By olike46 in forum Video Streaming DownloadingReplies: 7Last Post: 6th Nov 2022, 20:13 -
HELP for download audio file from MPD file only
By missdgsn in forum Video Streaming DownloadingReplies: 0Last Post: 19th Aug 2022, 12:50 -
Help To Download Student Audio File
By abrogard in forum AudioReplies: 2Last Post: 20th Apr 2021, 03:07
