Haven't been able to find much on a fix to this.
From a 4k HDR disc
What it looks like when playing
VLC snapshot
On Mac m1 with newest version installed.
				Results 1 to 10 of 10
	I believe VLC is sending the HDR metadata to its player. The player then passes that information along to the video renderer. The render then modifies the pixels as they are sent to the monitor. But the contents of video memory, what's used to save the snapshot, does not include the HDR transformation. Last edited by jagabo; 20th Dec 2024 at 12:43.
	As I stated I'm on Mac and Pot player doesn't support Intel Macs much less an arm 64 Mac which is what I have
	Is OpenGL available to you?
 There was a soloution in an old Reddit post using OpenGL.
 https://www.reddit.com/r/VLC/comments/rbilpn/hdr_to_sdr_tonemapping_feature/
 but it appears OpenG is deprecated on MacOS:
 https://developer.apple.com/library/archive/documentation/GraphicsImaging/Conceptual/O..._concepts.html
 Perhaps you can check the relevant VLC preferences at tools/preferences/all/video/output modules
 and see what's available
  Gray Glitches when I import videos into an editing softwareBy EccDom in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2024, 18:05
  View bookmarks made in VLC on VLC Android(galaxy ultra s23)By nille1234567 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2024, 02:47
  Virtualdub2 showing gray artifacting with MPG2By rmiller3 in forum EditingReplies: 8Last Post: 8th Jan 2024, 23:28
  PotPlayer - play video as black and white (gray scale)?By Ayaa in forum Software PlayingReplies: 5Last Post: 27th Aug 2022, 17:30
  MPC-HC and VLC show no video (black), but screenshots and audio are workingBy OddTheodora in forum Software PlayingReplies: 6Last Post: 22nd Nov 2020, 17:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
