Hi,
So I'm trying to De-interlace a dvd and clean up image as much as possible with some sharpness.
I tried to start this off with my limited knowledge of Avisynth. Most of it is based on the scripts that I was given help from this Forum previously but i understand that same script wont always be suitable for different videos.
If anyone can guide me through this it would be much appreciated.
here is sample of dvd:https://easyupload.io/cjwicq
this is my script so far:
a = LWlibavAudioSource("G:\6 directions files\sample\VTS_01_1 T80 2_0ch 256Kbps DELAY -288ms.ac3") # get audio (decompressed to PCM)
v = Mpeg2Source("G:\6 directions files\sample\VTS_01_1.d2v", Info=3) # get video
AudioDub(v,a) # join audio and video together
import("C:\Users\akuma\AviSynth+\plugins64+\Remove DirtMC.avs")
Crop(4, 56, -0, -76)
ColorMatrix(mode="rec.601->rec.709")
yadif()
RemoveDirtMC(10, false)
temporaldegrain2() #or use a simpler (faster) denoiser
AssumeFPS(24000, 1000, sync_audio=true) # audio sample rate reduced from 48000 to 46080 (lossless)
SSRC(48000) # convert audio to 48000 Hz samples
Prefetch(24)
Results 1 to 18 of 18
this is the same video and script from your other thread.
What is wrong with the output from this script? -
I'm not sure why you're using Yadif. It's a deinterlacer and your sample isn't interlaced.
Nor am I sure why you're converting to rec.709 as I see no resize to hi-def.
Also, your white levels should be lowered as they're somewhat blown out -
I used bwdif in my attempt on his previous thread, I chose to interpolate from 1 field,
the subtitles at the bottom looked clearer this way.
In the other thread sharc upscaled, but in the script above the OP removed the resize but left the colormatrix command.
Does this mean the OP doesn't weant to upscale? This is why I posted my question above, it's not clear.
This is the script I used in the previous thread
Code:function RemoveSpotsMC3x(clip clip, int "limit", bool "_grey") { _grey = default(_grey, false) limit = default(limit, 6) i=MSuper(clip,pel=2) bvec = MAnalyse(i,isb=false, blksize=8, delta=1, truemotion=true) fvec = MAnalyse(i,isb=true, blksize=8, delta=1, truemotion=true) backw = MFlow(clip,i,bvec) forw = MFlow(clip,i,fvec) clp=interleave(backw,clip,forw) clp=clp.RemoveSpots().RemoveSpots().RemoveSpots() # << original code # clp=clp.RemoveSpots().RemoveSpots() # << remove one call of removespot to make it faster clp=clp.SelectEvery(3,1) return clp } function RemoveSpots(clip input, bool "_grey", int "repmode") { _grey=default(_grey, false) repmode=default(repmode, 16) clmode=17 clensed=Clense(input, grey=_grey, cache=4) sbegin = ForwardClense(input, grey=_grey, cache=-1) send = BackwardClense(input, grey=_grey, cache=-1) alt=Repair(SCSelect(input, sbegin, send, clensed, debug=true), input, mode=repmode, modeU = _grey ? -1 : repmode ) restore=Repair(clensed, input, mode=repmode, modeU = _grey ? -1 : repmode) corrected=RestoreMotionBlocks(clensed, restore, neighbour=input, alternative=alt, gmthreshold=70, dist=1, dmode=2, debug=false, noise=10, noisy=12, grey=_grey) return corrected } aud=directshowsource("C:\Users\davex\Desktop\VTS_01_1.mpg",video=no) vid=mpeg2source("C:\Users\davex\Desktop\avs_test\cm2.d2v") audiodub(vid,aud) bwdif(field=0) RemoveSpotsMC3x(limit=2) mcdegrainsharp(bblur=0.12,csharp=0.36) AssumeFPS("ntsc_film", sync_audio=true).ResampleAudio(48000) -
Hi davexnet, It's a complete different DVD from previous thread. I would like to improve the video quality as much as possible basically (removing dirt and dust) and if upscale is possible too without the picture looking too bad then that too.
Also I don't know what filters to use to get the best possible improvement in quality. My knowledge of Avisynth is not good. -
You can just resize to a 4x3 size, eg. 960x720.
Here's a sample. Frames per second set to 23.976
I think the contrast/brightness/gamma could be improved a little more than this -
I used santiag() in the former thread for basically the same purpose. Don't know why the OP removed it now but deinterlaced, kept the colormatrix but skipped the subsequent upscale.....
Keep on learning. It's better than repeating the same or similar problems
Thanks, Looks better with some of the dirt removed. I noticed some parts of the hands/ arms missing in some frames in the fight scenes when using RemoveSpotsMC3x(limit=2) in the script so I replaced it with RemoveDirtMC instead and it seems to be better for the fight scenes especially but overall the RemoveSpotsMC3x(limit=2) was better at removing the bigger size dirts on normal paced motions.
Also i wasn't able to find mcdegrainsharp file anywhere so instead I used santiag(). Can someone help me with getting mcdegrainsharp file please.
Overall this is what I have so far:
a = LWlibavAudioSource("G:\6 directions files\VTS_01_1 T80 2_0ch 256Kbps DELAY -288ms.ac3") # get audio (decompressed to PCM)
v = Mpeg2Source("G:\6 directions files\VTS_01_1.d2v", Info=3) # get video
import("C:\Users\akuma\AviSynth+\plugins64+\santiag v1.6.avs")
santiag() #removes the residual combing artefacts
RemoveDirtMC(20, false) # remove spots (from dust, delamination)
spline36resize(1200,720) #square pixels
addborders(40,0,40,0) #pad to 1280x720
Prefetch(24),
If anything else can be done to improve on it, please advice me. Thanks -
Here's another try, cleaned up the edges a little more
Code:aud=directshowsource("C:\Users\davex\Desktop\VTS_01_1(1).mpg",video=no) vid=mpeg2source("C:\Users\davex\Desktop\avs_test\cm3.d2v") audiodub(vid,aud) checkmate(thr=8,max=6,tthr2=2) vinverse() RemoveSpotsMC3x(limit=2) crop(8,52,-0,-60) levels(0,0.92,255,0,255,coring=true) z_ConvertFormat(colorspace_op="470bg:601:170m:full=>709:709:709:full") nnedi3_rpow2(2, cshift="spline36Resize", fwidth=1212, fheight=720) addgrainc(var=0.6,uvar=0.0) sharpen(0.2) addborders(34,0,34,0) AssumeFPS("ntsc_film", sync_audio=true).ResampleAudio(48000)
Dvd interlacing
By Johnnysh in forum DVD RippingReplies: 37Last Post: 6th Dec 2020, 14:34 -
Best format / straightforward software to rip entire DVD collection?
By guy24s in forum DVD RippingReplies: 12Last Post: 18th May 2020, 06:48 -
Help digitizing large collection dvd's
By desertrider in forum DVD RippingReplies: 98Last Post: 1st Feb 2020, 14:35 -
Best way to transfer a DVD collection to a Synology NAS to play via Plex
By dzachau in forum Newbie / General discussionsReplies: 8Last Post: 30th Jan 2020, 13:05 -
Ripping dvd collection
By Lynnlee22 in forum DVD RippingReplies: 4Last Post: 31st Dec 2019, 20:47
