Is there any software other than EO Video that will convert .rm files to VCD-ready .mpeg's? I installed EO Video a while back and I remember it caused my system sound files not to play. I couldn't figure out how to correct this, so I uninstalled. Any advice?
Try TINRA but beware.....the sound will be so out of sync. EO Video is the way to go.
BTW, do you have the latest versions of all the players ??
If you are using Windows XP...why ??? it sucks -
Oh, yeah, I forgot about TINRA. I'm running Win98 (why did you think XP -- are there known problems with that and EO Video?).
My RealPlayer is version 6.09, WMP 7. I refuse to up to RealOne, or whatever it's called, since I guess it's no longer freeware and I don't use .rm files that much. I guess I could give EO Video another try; I just didn't like the way it took over the audio. I honestly couldn't figure out what it was doing, but as soon as I uninstalled it, the system audio re-appeared.
What is the best current AVI to MPEG 2 converting software?
By avz10 in forum Video ConversionReplies: 8Last Post: 2nd May 2012, 18:00 -
Best software to edit and burn mpeg video on PC?
By daysaf00 in forum Authoring (DVD)Replies: 3Last Post: 29th Jan 2012, 03:02 -
Feedback on software for converting Powerpoint Presentations to Video
By LJB in forum Newbie / General discussionsReplies: 3Last Post: 5th Jun 2009, 09:21 -
Taking video out of Premiere Pro 1.5 and converting with another software?
By vid83 in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2008, 19:55 -
Software to adjust/enhance brightness for MPEG-4 Video
By breakbeat in forum EditingReplies: 5Last Post: 23rd Nov 2007, 14:47
