my main monitor is 27" 1440p. someone is giving me their 24" 1080p. learning davinci resolve
1-is it possible to have the gpu output to 2 different resolutions?
2-I dont need 2 monitors except for editing. how do I disable the 2nd 24" monitor except for editing?
I just have a 1080 but have been on the lookout for a 2080ti/3080/3080ti/3090 depending on prices ive set.
1: sure
Before I had a HPZ27Q@5120x2880 and a INNOCN 27M2U@3840x2180 and had to replace the first with a Samsung Odyssey g9@7680x2160.
(At one time I had the HPZ27Q and two 1080p displays, never had a problem.)
2: turn it off, if you don't need it.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
that was easy. overthinking things. thanks so much
so turn it off through right click? display settings? -
I usually use the power button at the monitor to turn my monitor off, not sure whether there is a way to power off a monitor in Windows. (there probably is, I just never used it
Yes, you can use two monitors with different resolutions easily; your GPU will handle it without any issues. For turning off the second monitor, right-click on the desktop, go to 'Display Settings,' and disable it when not needed, or just use the power button on the monitor.
Point of clarification: you can use 2 different resolutions WHEN YOU ARE USING EXTENDED MODE. If using duplicate/clone/mirror mode, the resolutions will be the same.
Old CRT monitor shows scan lines near bottom on the monitor
By loninappleton in forum Newbie / General discussionsReplies: 12Last Post: 30th Jan 2024, 16:20 -
Here is my Setup. What do you think?
By plehoediv in forum Capturing and VCRReplies: 103Last Post: 22nd May 2023, 12:39 -
ML/AI based video editing? Finding patterns in editing footage.
By GoodEnough in forum Newbie / General discussionsReplies: 9Last Post: 9th May 2023, 18:22 -
Video Editing hard drive setup
By bridgyguy in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2021, 08:51 -
Help with my capture setup
By DocSnyd3r in forum Capturing and VCRReplies: 3Last Post: 16th Jan 2020, 15:04
