Hello. I found this ffmpeg code to downscale 1080p to 720p:
It should have good quality in small size. It use better scaling method than default.Code:for %%f in (*.mkv) do ( echo Processing %%f... ffmpeg -i "%%f" -c:v libx264 -crf 21 -level 3.1 -preset slow -tune film -filter:v scale=-1:720 -sws_flags lanczos -c:a copy -c:s copy "output\%%f.mkv" )
But I have not powerful CPU and good GPU.
So, how to modify this command to use NVIDIA CUDA instead?
I found something like that but not sure how to add tune film and sws_flags lanczos
Code:ffmpeg -hwaccel cuda -hwaccel_output_format cuda -i "%%f" " -c:a copy -c:s copy -vf "scale_cuda=-1:720" -c:v h264_nvenc "output_file.mp4"
Win10 64bit
FFMPEG from here https://www.gyan.dev/ffmpeg/builds/
With this command:
I have about 200fps with Nvidia 1050Ti while with CPU i have under 20fpsCode:ffmpeg -y -hwaccel cuda -hwaccel_output_format cuda -i "%%f" -c:v h264_nvenc -profile:v high -level 4.0 -tune hq -preset p7 -vf "scale_cuda=-1:720" -b:v 0 -sws_flags lanczos -cq 27 -c:a copy -c:s copy "output\%%f.mkv"
I found that nvenc is ignoring crf 19
and I should use cq to set quality (crf 19 = cq from 23 to 25)
And I can't find anything what is is "-tune hq" if I use "-tune film" I get error
And I don't know -sws_flags lanczos is used because I have no fps drop when using that
Edit:
Also tried that:
It's encoding with about 150fpsHTML Code:ffmpeg -y -i "%%f" -c:v h264_nvenc -cq 25 -level 3.1 -preset slow -tune hq -filter:v scale=-1:720 -sws_flags lanczos -c:a copy -c:s copy "output\%%f.mkv"
try to follow https://docs.nvidia.com/video-technologies/video-codec-sdk/12.2/ffmpeg-with-nvidia-gpu/index.html
Based on above NVidia guide seem ffmpeg commandline should look like this:
Use one (NVidia seem to accept both) of bellow HW accelerated resizers:Code:ffmpeg -y -vsync 0 -hwaccel cuda -hwaccel_output_format cuda -i input.mp4 -vf scale_cuda=1280:720 -vf scale_npp=1280:720 -c:a copy -c:v h264_nvenc -preset p7 -tune hq -b:v 5M -bufsize 5M -maxrate 10M -qmin 0 -g 250 -bf 3 -b_ref_mode middle -temporal-aq 1 -rc-lookahead 32 -i_qfactor 0.75 -b_qfactor 1.1 output.mp4
eitherorCode:-vf scale_cuda=1280:720
Code:-vf scale_npp=1280:720
Pandy's command line encodes at about 550 fps on my RTX 4060 (1080p to 720p). Just use -qp N instead of -b:v 5M if you want "quality" based encoding.
Of course there is possibility to tweak both resizers (default resize algorithm seem to be bicubic) also there is possibility to use libplacebo with very high quality resize filters and/or custom shaders - how this impact performance is unknown to me - my last NVidia card was ancient Geforce 4 440MX (over 20 years ago).
ffmpeg transcode H.265 to H.264 by Nvidia CUDA error
By slick zheng in forum Video ConversionReplies: 18Last Post: 4th Aug 2023, 01:37 -
How To Downscale 4K 2160p HEVC 10 bit Video To 2K 1080p AVC 10bit
By LouieChuckyMerry in forum Video ConversionReplies: 32Last Post: 26th May 2023, 03:07 -
will there be quality loss if i convert from 1080p to 720p
By cns00 in forum Video ConversionReplies: 9Last Post: 25th May 2022, 02:01 -
Intel QSV VS Nvidia CUDA
By BlurayHD in forum Newbie / General discussionsReplies: 34Last Post: 18th Oct 2020, 04:26 -
Best Way To Downscale 1080p 30fps Sports Video to 720p for Bluray?
By AndersonJames in forum RestorationReplies: 10Last Post: 18th Jun 2020, 14:25
