threev:
I use CBR. In fact, I use the RT_CBR (real-time constant/controlled bitrate) setting. My eyes cannot see the difference between RT_CBR and regular CBR. So, since the pop-up window in TMPGEnc says not to use it, I am being a rebel.
On 2001-08-06 20:05:13, threev wrote:
Just curious, do you use CBR or CQ setting?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Results 31 to 32 of 32
Just for the record, I've used the fxVHS filter - it's quite remarkable. It does a marvelous job getting rid of those kind of streaky wavy lines that tend to run across VHS (or in my case S-VHS) tapes. I just used it in it's default configuration and it worked well. I've found that using it first, followed by the temporal cleaner filter in virtual dub does a very good job cleaning up VHS tape.
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 05:14 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 06:10 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 22:56 -
Trying to make AVCD/VCD with audio data
By Vejita-sama in forum Authoring (VCD/SVCD)Replies: 2Last Post: 4th Aug 2007, 15:15
