I did remux BD a while ago before HDR/DoVi existed using MKVToolNix, I tried with a BD which has both HDR and DoVi, when reading MediaInfo after, it does not say Dovi.
BDInfo
If I leave all the tracks checked, which shows 2 video tracks in MKVToolNix, resulted file in MediaInfo also has 2 video tracks and no trace of DoVi.Code:Video: MPEG-H HEVC Video / 62950 kbps / 2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / HDR10 / BT.2020 * Video: MPEG-H HEVC Video / 68 kbps / 1080p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 10 bits / Dolby Vision / BT.2020
But what I want is just a video track with both HDR and DoViCode:Video #1 ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 44 min Bit rate : 63.0 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.317 Stream size : 46.0 GiB (87%) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 966 cd/m2 Maximum Frame-Average Light Level : 364 cd/m2 Original source medium : Blu-ray Video #2 ID : 2 ID in the original source medium : 4117 (0x1015) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 44 min Bit rate : 68.9 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.001 Stream size : 51.6 MiB (0%) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : BT.2020 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Original source medium : Blu-ray
Is here any guide that shows how to do it, using MKVToolNix or other software?Code:Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
I tried DGDemux and something is wrong, after I mux back using MKVMerge, the playback is 3h, image/sound are too fast and out of sync.
To be sure it's not a MKVMerge problem I tried to demux using tsMuxer and it worked fine. Seems to be from the audio, if I use the audio from tsMuxer with the hevc from DGDemux it works, any idea why?Code:dgdemux -i /media/user/TITLE/BDMV/PLAYLIST/00002.mpls -o .
I also have another question, which is the best to use, mergedv81 flag or mergedv flag?Last edited by Sawyer; 19th Dec 2024 at 10:56.
Two things about muxing Dolby Vision P7 to mkv. The baselayer and enhancement layer have to be interleaved into one track. Dovi_tool can do this. And with any DoVi profile, always force-set the "Default duration/FPS" (MTX GUI) to the proper value.
I never use the DoVi options of DGDemux; want to do things manually with dovi_tool.Last edited by Ennio; 20th Dec 2024 at 00:02.
Have tried 24000/1001 on the video track "Default duration/FPS", same stuff happens, the duration is double, 3h28m instead of 1h44m.
The audio tracks extracted by DGDemux and tsMuxer have a difference of ~3MB and the profile/duration are different.
So DGDemux sets a duration and a different profile than tsMuxer.Code:$ ffprobe -v error -show_format -show_streams audio.dts [STREAM] index=0 codec_name=dts codec_long_name=DCA (DTS Coherent Acoustics) profile=DTS codec_type=audio codec_tag_string=[0][0][0][0] codec_tag=0x0000 sample_fmt=fltp sample_rate=48000 channels=6 channel_layout=5.1(side) bits_per_sample=0 id=N/A r_frame_rate=0/0 avg_frame_rate=0/0 time_base=1/90000 start_pts=0 start_time=0.000000 duration_ts=1467127840 duration=16301.420444 bit_rate=1536000 max_bit_rate=N/A bits_per_raw_sample=N/A nb_frames=N/A nb_read_frames=N/A nb_read_packets=N/A DISPOSITION:default=0 DISPOSITION:dub=0 DISPOSITION:original=0 DISPOSITION:comment=0 DISPOSITION:lyrics=0 DISPOSITION:karaoke=0 DISPOSITION:forced=0 DISPOSITION:hearing_impaired=0 DISPOSITION:visual_impaired=0 DISPOSITION:clean_effects=0 DISPOSITION:attached_pic=0 DISPOSITION:timed_thumbnails=0 [/STREAM] [FORMAT] filename=audio.dts nb_streams=1 nb_programs=0 format_name=dts format_long_name=raw DTS start_time=0.000000 duration=16301.420444 size=3129872725 bit_rate=1535999 probe_score=51 [/FORMAT] $ ffprobe -v error -show_format -show_streams 00000.track_4352_eng.dts [STREAM] index=0 codec_name=dts codec_long_name=DCA (DTS Coherent Acoustics) profile=DTS-HD MA codec_type=audio codec_tag_string=[0][0][0][0] codec_tag=0x0000 sample_fmt=s32p sample_rate=48000 channels=6 channel_layout=5.1(side) bits_per_sample=0 id=N/A r_frame_rate=0/0 avg_frame_rate=0/0 time_base=1/90000 start_pts=0 start_time=0.000000 duration_ts=N/A duration=N/A bit_rate=N/A max_bit_rate=N/A bits_per_raw_sample=24 nb_frames=N/A nb_read_frames=N/A nb_read_packets=N/A DISPOSITION:default=0 DISPOSITION:dub=0 DISPOSITION:original=0 DISPOSITION:comment=0 DISPOSITION:lyrics=0 DISPOSITION:karaoke=0 DISPOSITION:forced=0 DISPOSITION:hearing_impaired=0 DISPOSITION:visual_impaired=0 DISPOSITION:clean_effects=0 DISPOSITION:attached_pic=0 DISPOSITION:timed_thumbnails=0 [/STREAM] [FORMAT] filename=00000.track_4352_eng.dts nb_streams=1 nb_programs=0 format_name=dts format_long_name=raw DTS start_time=0.000000 duration=N/A size=3126352528 bit_rate=N/A probe_score=51 [/FORMAT]
The thing is that there isn't just one disc but all of them, the sources are fine I'm thinking since it works fine using the audio demuxed using tsMuxer. Somehow the duration and the different profile DGDemux adds to the audio breaks MKVToolNix.
I'm on Linux, most people do this on Windows probably, but I don't see this as being a problem.
Mp4 Remux into different container
By therock003 in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2024, 07:27 -
MKVtoolnix Remux Problem
By robbie1407 in forum Video ConversionReplies: 21Last Post: 24th Jul 2023, 05:49 -
Can someone clarify my options if I have a DoVi video but no DoVi screen?
By Asterra in forum Software PlayingReplies: 9Last Post: 30th Nov 2022, 14:10 -
mkv remux to BD problems
By badflame in forum Authoring (Blu-ray)Replies: 9Last Post: 26th Mar 2021, 03:11 -
Remux vs Encodes?
By Zach_N85 in forum Video ConversionReplies: 9Last Post: 15th Mar 2021, 14:17
