Hello,
Can anyone please recommend suitable software that can process a MKV file to normalise surround sound (5+1) audio files.
You can use clever FFmpeg-GUI.
Load your video, click main page, click encode audio stream, select your 5.1 audio stream (if there are different audio streams), click volume detection.
If finished, you're in the audio encoding section.
If an audio gain value is found, it will be displayed under Filter as volume with a positive db value.
Then select your encoder and the desired channels and click encode. Done.
In old surround sound in 5.1 DTS & AC3 who is better ?
By tkp206093 in forum AudioReplies: 1Last Post: 4th Jul 2023, 12:33 -
Converting Audio Files with 5.1 to play on DVD surround sound setup
By rayhigh in forum AudioReplies: 1Last Post: 4th Jan 2022, 15:04 -
How to remove one of two audio tracks in a mkv file?
By BooSnow in forum AudioReplies: 4Last Post: 18th Oct 2020, 11:00 -
Removing Right Audio Channel in MKV file
By yuzu28 in forum Video ConversionReplies: 4Last Post: 16th Aug 2020, 00:06 -
Dialogue normalisation VS Audio conversion
By RajaSteve in forum AudioReplies: 2Last Post: 5th Apr 2020, 14:04
