Hi all,
I have an issue with a VHSc tape that I was recently sent which was originally recorded in Pakistan (not sure of the equipment)
Whenever I try to convert the tape to digital (on various VCR/camcorders) the output shows interference and loss of colour, even though through the viewfinder of the camcorder I'm using, the recording plays fine.
Would appreciate any help or guidance someone might be able to give on how I could correct the output recording.
I'm using a Panasonic G202 VHSc unit and OBS/CVS to do the conversion.
Through a Capture card and a Mini AV2HDMI converter
Many thanks in advance
David
Your tapes are most likely MESECAM, Some PAL camcorders can playback MESECAM but you need a capture device that accepts MESECAM, It is not going to be a chinese non brand one for sure like the one you are using now, look for a good USB capture device, avoid things that have words such as HDMI, easycap, elgato and OBS.
Pakistan has always been a normal PAL video country. but anything is possible...
ok thanks Sam.
Hopefully another member might be able to offer a suggestion.
Thanks in advance
VHS-C tapes Converting to DVD
By Lobo69 in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2024, 14:35 -
Seeking for advice converting old V8 tapes
By satimis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 41Last Post: 18th Sep 2023, 02:29 -
How to properly capture VHS-C tapes?
By Krazern in forum Capturing and VCRReplies: 2Last Post: 23rd Jun 2023, 06:30 -
Problems with VHSC adapter, it always eats tape.
By JigSawJoker in forum Capturing and VCRReplies: 2Last Post: 3rd Jun 2021, 15:09 -
How to properly adjust aspect ratio when converting VHS to digital
By aera in forum Capturing and VCRReplies: 52Last Post: 10th Jan 2020, 05:45
