First of all, my PC is old and weak but it does usually play videos with no issues. I'm trying to watch a 3-hour long movie but the lags are unbearable. I'm using PotPlayer but I've checked with two other players (VLC and MPC-BE) and there is no difference. I can easily play a 1h:50m long movie, but apparently 3 hours is more than my system can handle. I figured that if the long duration is really the issue, then trimming the movie into two smaller parts would help. I used Avidemux to split the video without re-encoding but the lags are still there. So what's going on?![]()
It might also have to do with the format, codec used - Newer codecs require more decoding power. Or perhaps the resolution of that file is higher than the others.
You can use mediainfo (view=>text) for more information on that file
You might have to convert it to an "easier" format for your computer to handle
Some formats can be hardware accelerated for smooth playback, offloading the CPU. You would have to post more details on specs of the CPU, GPU
Subtitle Edit 3.6.7 : Audio playback lags waveform/spectrogram
By Francis Lee in forum SubtitleReplies: 3Last Post: 14th Dec 2022, 15:31 -
Premiere Pro lags when moving the timeline slider and crashes while editing
By Trial4life in forum EditingReplies: 1Last Post: 20th Jan 2022, 08:57 -
Video Lags Audio Problem
By Dbraun4 in forum Newbie / General discussionsReplies: 0Last Post: 27th Dec 2020, 14:23 -
Software to repair/fix video shutters/skips/lags
By kalemvar1 in forum Video ConversionReplies: 2Last Post: 13th May 2020, 17:33
