Results 1 to 10 of 10
  1. Hey, can few people help me getting the .mp4 links for the video in phoning app, the option after login comes is calls(from call section itself free to access) https://play.google.com/store/apps/details?id=co.weverse.phoning
    i want 73 videos link. If you guys have rooted device and have fiddler to inspect network request it would be because i don't have rooted device and the android emulator from android is not working evertime i open the app it says try again later.
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You should root your device and get fiddler working.
  3. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    I did that, but everytime i proxy the network and try to open the app, it says some error occured, try again later. Someone said its because ssl pinning 🤔
    Jul 2023
    India
    patch the apk using apk-mitm or use frida for ssl unpinning
    read more -
    https://github.com/niklashigi/apk-mitm
    https://httptoolkit.com/blog/frida-certificate-pinning/
  5. Originally Posted by sarvo99 View Post
    read more -
    Thank you, i have one doubt as i have seen in some videos how to unpinning ssl using Frida, with that process we can unpin ssl with one application only at a time right i mean we have to specify that app com.----.android. its not like system wide unpinning ? If i face same issue with an app i have to again do the same for the app creating issues ?
  6. videos are 1080p but network request only showing resolution till 720p, any idea about that ?
  7. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Since you're talking about requests, I assume you succeeded in setting up Fiddler and everything works fine?
  8. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Yes, but not getting the 1080p datas there. Some said about assign hmac to url but i dunno how to do that or doing mitm attack . Totally noob
    Oh and downloading is really slow
    Jul 2023
    India
    if the video plays in 1080p on the app and you are intercepting requests successfully the request for it will be their in the log u just cant find it i assume.
    or just the app is playing in 720p for some reason.
  10. Originally Posted by sarvo99 View Post
    Possibly yes, but says default video as 720p, and i have double checked there is no 1080p so probably there no 1080p resolution. Thanks bhai ��
