Results 1 to 30 of 37
  1. N_m3u8DL-RE "https://fr5-6-dash-pvr.zahs.tv/HD_giallo_it/1733148299200/1733157000000/m.mpd?z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMTGG43JMQ6TCOBQ IVDDKRSDGJBUKMJYGI3UGLJXGY3EIOKCGY4DCQRTIIYDKOCDEZ WWC6DSMF2GKPJVGAYDEJTNNFXHEYLUMU6TMMBQEZYHEZLGMVZH EZLEL5WGC3THOVQWOZJ5NF2CM43JM46TIMS7GE3DMODBGM3TOM ZWGZQWKNZTMIYTGZDCGJTDGMDFME2TCMRRGI2SM43VMJ2GS5DM MVZT22DJMRSGK3RNONSGQJTVONSXEX3JMQ6TGMZXGUYDAMJTEZ 3D2MA" --save-name "11" --check-segments-count false -M mp4
    Not work, why?
    It should be an unprotected mpd from Zattoo.
    Zattoo opens with Swiss VPN.
    To download I should be in Switzerland, I'm using a VPN but nothing, think I'm not in Switzerland nm3u8dl-re
  2. Originally Posted by nette View Post
    Not work, why?
    HD_giallo_it IT = Italian VPN works fine
    N_m3u8DL-RE "https://fr5-6-dash-pvr.zahs.tv/HD_giallo_it/1733148299200/1733157000000/m.mpd?z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMTGG43JMQ6TCOBQIVDDKRSDGJBUKMJYGI3UGLJXGY3EIOKCGY4DCQRTIIYDKOCDEZWWC6DSMF2GKPJVGAYDEJTNNFXHEYLUMU6TMMBQEZYHEZLGMVZHEZLEL5WGC3THOVQWOZJ5NF2CM43JM46TIMS7GE3DMODBGM3TOMZWGZQWKNZTMIYTGZDCGJTDGMDFME2TCMRRGI2SM43VMJ2GS5DMMVZT22DJMRSGK3RNONSGQJTVONSXEX3JMQ6TGMZXGUYDAMJTEZ3D2MA" -M format=mkv
  3. Originally Posted by nette View Post
    Not work, why?
    your command work fine. your issue is due to your VPN, no other
    and (just a tip) add --no-log to can't save log txt about your download
  4. the mpd link changes.
  5. Originally Posted by Silv3r View Post
    Not work, why?
    Unable to establish connection. Persistent rejection of target computer.
    new mpd link: https://oldpvr1-dash-pvr.zahs.tv/HD_giallo_it/1733148299200/1733157000000/m.mpd?z32=MF...UYDAMJTEZ3D2MA
  6. icem but why can't I?
    what version of nm3u8dl re ?
    what vpn did you use?
  7. Originally Posted by lomero View Post
    again your mpd work fine ...
    [Attachment 84059 - Click to enlarge]
    It doesn't work for me. I don't know what to do.
    do you have mp4decrypt and ffmpeg? which?
    I have Nord VPN.
    It works until a few days ago.
  8. Show 'cmd' window.
  9. Originally Posted by LZAA View Post
    Show 'cmd' window.
    I wrote it above.
Name:	Immagine 2024-12-10 182716.png
  10. i don't use vpn for that
    RE same version
    ffmpeg yes, on same folder with RE. but your error is about connection
    mp4decrypt no need for this video (no encryption)
    try to change DNS. try google dns or cloudflare. use dns-jumper for that - free tool here: https://www.sordum.org/7952/dns-jumper-v2-3/
  11. Without VPN:
    yt-dlp -F "https://oldpvr1-dash-pvr.zahs.tv/HD_giallo_it/1733148299200/1733157000000/m.mpd?z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMTGG43JMQ6TCOBQ IZCDSQ2CIJATAQJZGM2TCLJUHE4TSMZSGA3DGQKEIJDEKNCEEZ WWC6DSMF2GKPJVGAYDEJTNNFXHEYLUMU6TMMBQEZYHEZLGMVZH EZLEL5WGC3THOVQWOZJ5NF2CM43JM46TIMS7MQ2WCMJQMJRGKZ RUGNRDMOJZMU2DONTDGIYWGOJZG43GIOBYMJQSM43VMJ2GS5DM MVZT22DJMRSGK3RNONSGQJTVONSXEX3JMQ6TGMZXGUYDAMJTEZ 3D2MA"
    [generic] Extracting URL: https://oldpvr1-dash-pvr.zahs.tv/HD_giallo_it/1733148299200/1733157000000/m.mpd?z32=MF...UYDAMJTEZ3D2MA
    [generic] m: Downloading webpage
    WARNING: [generic] Falling back on generic information extractor
    [generic] m: Extracting information
    [info] Available formats for m:
    ID EXT RESOLUTION FPS │ TBR PROTO │ VCODEC VBR ACODEC ABR MORE INFO
    5 m4a audio only │ 128k dash │ audio only mp4a.40.2 128k [it] DASH audio, m4a_dash
    4 mp4 512x288 25 │ 452k dash │ avc1.4d4015 452k video only DASH video, mp4_dash
    3 mp4 512x288 25 │ 700k dash │ avc1.4d4015 700k video only DASH video, mp4_dash
    2 mp4 768x432 25 │ 1300k dash │ avc1.4d401e 1300k video only DASH video, mp4_dash
    1 mp4 1280x720 25 │ 2800k dash │ avc1.4d401f 2800k video only DASH video, mp4_dash
    0 mp4 1280x720 50 │ 4800k dash │ avc1.4d4020 4800k video only DASH video, mp4_dash
  12. yt-dlp.exe and ffmpeg.exe on same folder?
  13. Originally Posted by lomero View Post
    RE same version
    ffmpeg.exe 141 mb ?
  14. 'Without VPN'.
    Isn't it clear?!
  15. Nothing with dns jumper, same problem
  16. Originally Posted by LZAA View Post
    'Without VPN'.
    Isn't it clear?!
    it doesn't work in any case
  17. 1. Do this:
    wget "https://oldpvr1-dash-pvr.zahs.tv/HD_giallo_it/1733148299200/1733157000000/m.mpd?z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMTGG43JMQ6TCOBQ IZCDSQ2CIJATAQJZGM2TCLJUHE4TSMZSGA3DGQKEIJDEKNCEEZ WWC6DSMF2GKPJVGAYDEJTNNFXHEYLUMU6TMMBQEZYHEZLGMVZH EZLEL5WGC3THOVQWOZJ5NF2CM43JM46TIMS7MQ2WCMJQMJRGKZ RUGNRDMOJZMU2DONTDGIYWGOJZG43GIOBYMJQSM43VMJ2GS5DM MVZT22DJMRSGK3RNONSGQJTVONSXEX3JMQ6TGMZXGUYDAMJTEZ 3D2MA"
    The name is too long, 305 chars total.
    Trying to shorten...
    New name is m.mpd@z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMTGG43JMQ6TCOBQ IZCDSQ2CIJATAQJZGM2TCLJUHE4TSMZSGA3DGQKEIJDEKNCEEZ WWC6DSMF2GKPJVGAYDEJTNNFXHEYLUMU6TMMBQEZYHEZLGMVZH EZLEL5WGC3THOVQWOZJ5NF2CM43JM46TIMS7MQ2WCMJQMJRGKZ RUGNRDMOJZMU2DONTDGIYWGOJZG43GIOBYMJQSM.
    --2024-12-10 20:06:31-- https://oldpvr1-dash-pvr.zahs.tv/HD_giallo_it/1733148299200/1733157000000/m.mpd?z32=MF...UYDAMJTEZ3D2MA
    Resolving oldpvr1-dash-pvr.zahs.tv (oldpvr1-dash-pvr.zahs.tv)... 91.123.100.208, 91.123.100.208
    Connecting to oldpvr1-dash-pvr.zahs.tv (oldpvr1-dash-pvr.zahs.tv)|91.123.100.208|:443... connected.
    HTTP request sent, awaiting response... 200 OK
    Length: 3065 (3,0K) [application/dash+xml]
    Saving to: 'm.mpd@z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMTGG43JMQ6TCOB QIZCDSQ2CIJATAQJZGM2TCLJUHE4TSMZSGA3DGQKEIJDEKNCEE ZWWC6DSMF2GKPJVGAYDEJTNNFXHEYLUMU6TMMBQEZYHEZLGMVZ HEZLEL5WGC3THOVQWOZJ5NF2CM43JM46TIMS7MQ2WCMJQMJRGK ZRUGNRDMOJZMU2DONTDGIYWGOJZG43GIOBYMJQSM'
    m.mpd@z32=MF2WI2LPL 100%[===================>] 2,99K --.-KB/s in 0s
    2024-12-10 20:06:32 (21,4 MB/s) - 'm.mpd@z32=MF2WI2LPL5RW6ZDFMNZT2YLBMMTGG43JMQ6TCOB QIZCDSQ2CIJATAQJZGM2TCLJUHE4TSMZSGA3DGQKEIJDEKNCEE ZWWC6DSMF2GKPJVGAYDEJTNNFXHEYLUMU6TMMBQEZYHEZLGMVZ HEZLEL5WGC3THOVQWOZJ5NF2CM43JM46TIMS7MQ2WCMJQMJRGK ZRUGNRDMOJZMU2DONTDGIYWGOJZG43GIOBYMJQSM' saved [3065/3065]
    or
    2. Restore your system from a restore point or image. Something is broken.
  18. Nothing
Name:	Immagine 2024-12-10 185518.png
  19. Originally Posted by nette View Post
    yes. and 141MB (full version) or essential version (about 80MB) is the same
    anyway your issue is due to your connection, not for ffmpeg or RE. maybe your provider lock some connection (but weird)
    and yt-dlp also work fine
    [Attachment 84065 - Click to enlarge]
  20. 'Unable to connect to proxy'???
  21. Originally Posted by nette View Post
    Your IP is probably blocked
    Try another country
  22. Originally Posted by LZAA View Post
    1. Do this:
    or
    I don't understand the first point
  23. Originally Posted by IceM View Post
    Try another country
    ip blocked, why? How can I know?
  24. Google -> Wget
  25. install windscribe vpn https://windscribe.com/install/desktop/windows
    on free mode you can choose some country. use that for your download
  26. Originally Posted by Frieren View Post
    u can use yt-dlp online:
    https://ytdlp.online/
    nice to know. but i've tried and get error
    [download] 4.5% of ~ 1.58GiB at 461.22KiB/s ETA 01:01:17 (frag 75/1643)ERROR: Data must be padded to 16 byte boundary in CBC mode
    Command execution completed
    Download File
    why this error ? and this site download my video also when i'm offline?
  27. Originally Posted by whs912km View Post
    Download File
    u have 2 accounts here?
