This doesn't help you, but I never had the crashing issue with DVDA,
Like sharc, I didn't like that it's muxer had problems with higher bitrate x264 streams, also I didn't like the GUI which looked like something from the 90's , and it didn't have some features like popup menus. I preferred Encore for for consumer BD authoring
Back then , another freeware was multiavchd - it works ok, there are tutorials/guides - and can make decent output, semi fancy menus.
EasyBD Studio Lite is the freeware version, and it's very limited, but the muxing engine is good and will pass strict verifiers
Today, maybe TMPGenc Authoring Works, but I've never used it
Results 31 to 34 of 34
I'm not liking mitlavchd, but do appreciate the tip about the file extension bs.
I find it funny your dislike of the 90s gui of DVD Architect. Not sure how that's a bad thing - it's way more intuitive and functional than what multiavchd opens to. But, to each their own.
I'll have to check out Encore. -
DVD Architect was quite unique, they went their own way to design a DVD for users. Most menu authoring software kind of follow set consensus made by DVD Maestro, then successor DVD Lab Pro.
So if you started with Architect you'd kind of hate the rest and vice versa. -
I loved DVD Lab Pro, wish I could find a blu-ray version of that.
I was having no problems or dislike of DVD Architect until it started crashing.
They both seem to have a logic to simply importing content, laying out a menu, authoring how it works, and making a disc.
Nothing else seems to come close to the level of functionality of that. I'm not sure that current programmers have any concept of functionality anymore.
BD Wizard how to demux video files for Blu-ray authoring
By mikey128v in forum Authoring (Blu-ray)Replies: 28Last Post: 19th Jan 2023, 18:27 -
best PAID blu-ray authoring software
By muddy7 in forum Authoring (Blu-ray)Replies: 12Last Post: 30th Nov 2021, 19:57 -
What software is best for authoring blu-ray/dvd?
By MSU92AZ in forum Authoring (Blu-ray)Replies: 7Last Post: 21st Feb 2021, 13:54 -
Blu-Ray authoring
By rimaslagu79 in forum Authoring (Blu-ray)Replies: 9Last Post: 11th Nov 2020, 00:26 -
Need a new Blu-Ray Authoring package
By dswalen in forum Authoring (Blu-ray)Replies: 16Last Post: 20th Mar 2020, 09:57
