Results 1 to 12 of 12
    May 2016
    Lithopolis, OH United States
    I'm trying to do a Direct Stream Copy of a video that I want to trim. My original plan was to use Stream Copy, but in my experience, the audio and video can get out of sync. The problem is that my caching input driver won't let me use Direct Stream Copy. What should I do? Should I disable the caching input driver in VirtualDub2, or should I just take my chances with Stream Copy? The video is not very long, so it shouldn't take too long to process.
    Mar 2008
    Have you tried Avidemux? It might be simpler for this
    May 2016
    I will give that a try as I mostly used Virtualdub2.
    Mar 2008
    Or, in virtualdub2, instead of video/stream copy
    use file/export/stream copy
    May 2016
    Will it work for trimmed videos?
    Mar 2008
    It worked on a avi file I played with where I used the cursor on the timeline to set cut in and cut out point,
    I got the trim I expected.
    Just give it a go and see. If it doesn't work for you provide full details (mediainfo text view)
    of the file in question
    May 2016
    I will take your advice to heart as I am worried. I do not want to have a repeat performance of happened on my last computer. I have a slightly better computer now, so I think it could make a difference.
    Mar 2008
    What happened on your last computer?
    May 2016
    I would sometimes get some audio and video desyncs in some videos. It also wasn't built for video editing or conversion as sometimes it would slow down to a crawl when I use FFMPEG.
    May 2016
    I ended up using Avidemux since it allows me to trim the video and set the endpoint precisely where I want. So far, it works well, and the video output doesn't show any errors.
    I also tried using VirtualDub2 to create a "Direct Stream Copy" from the video, but I encountered an error: "Direct stream copy cannot be used with this video stream. You may want to select a different Input Driver." The video was created using an FFMPEG dumper, but it seems this specific dump isn’t compatible.
    I attempted the "Stream Copy" method you mentioned, but the results were inconsistent—it often didn’t cut exactly where I placed the marker and was off by a few seconds. For reference, the video is an MP4 file.
    This is the orginal video:
    General
    Complete name                            : ************.mp4
    Format profile                           : Base Media
    Codec ID                                 : isom (isom/iso2/avc1/mp41)
    File size                                : 9.63 GiB
    Duration                                 : 3 h 9 min
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 7 278 kb/s
    Frame rate                               : 59.940 FPS
    Writing application                      : Lavf58.76.100
    Video
    Format profile                           : High@L4.2
    Format settings                          : CABAC / 4 Ref Frames
    Format settings, Reference frames        : 4 frames
    Codec ID                                 : avc1
    Codec ID/Info                            : Advanced Video Coding
    Source duration                          : 9 min 29 s
    Bit rate                                 : 6 959 kb/s
    Width                                    : 1 194 pixels
    Height                                   : 896 pixels
    Display aspect ratio                     : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 59.940 (59940/1000) FPS
    Bits/(Pixel*Frame)                       : 0.109
    Stream size                              : 9.21 GiB (96%)
    Source stream size                       : 9.21 GiB (96%)
    Writing library                          : x264 core 164 r3075 66a5bc1
    Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    mdhd_Duration                            : 11368305
    Codec configuration box                  : avcC
    Audio
    Format                                   : AAC LC
    Format/Info                              : Advanced Audio Codec Low Complexity
    Codec ID                                 : mp4a-40-2
    Source duration                          : 3 h 9 min
    Source_Duration_LastFrame                : -23 ms
    Bit rate mode                            : Variable
    Bit rate                                 : 304 kb/s
    Maximum bit rate                         : 384 kb/s
    Channel layout                           : L R
    Sampling rate                            : 44.1 kHz
    Frame rate                               : 43.066 FPS (1024 SPF)
    Stream size                              : 412 MiB (4%)
    Source stream size                       : 412 MiB (4%)
    Default                                  : Yes
    Alternate group                          : 1
    This is from the video I outputted in Virtualdub2:
    General
    Complete name                            : *************.mp4
    Overall bit rate                         : 7 280 kb/s
    Writing application                      : Lavf57.79.100
    Video
    Codec ID                                 : avc1
    Source duration                          : 9 min 27 s
    Bit rate                                 : 6 963 kb/s
    Height                                   : 896 pixels
    mdhd_Duration                            : 11366118
    Audio
    Format                                   : AAC LC
    Bit rate mode                            : Constant
    Bit rate                                 : 304 kb/s
    Default                                  : Yes
    Alternate group                          : 1
    This is from the video I outputted in AVIDemux.
    General
    Complete name                            : *********.mp4
    Video
    Codec ID                                 : avc1
    Bit rate                                 : 6 961 kb/s
    Height                                   : 896 pixels
    Frame rate mode                          : Variable
    mdhd_Duration                            : 11365838
    Audio
    Format                                   : AAC LC
    Source_Duration_LastFrame                : -12 ms
    Nominal bit rate                         : 304 kb/s
    Maximum bit rate                         : 304 kb/s
    Default                                  : Yes
    Alternate group                          : 1
    mdhd_Duration                            : 11365911
    Mar 2008
    Start the cut in point on an I frame then it should be ok.
    To position to an I frame, hold shift key and left or right arrows in vdub2,
    and up and down arrows in Avidemux
    This is required when doing stream copy cuts from
    typical consumer video such as this
    For frame accurate cuts you have to re-encode the video or use a
    Smart cutter such as Tmpgenc Smart Renderer.
    Prowo's Clever Ffmpeg Gui can also do it
    May 2016
    If Virtualdub2 does not let me do those things, I can use AVIDemux and/or the other programs you mentioned. I feel a little confident now and I think I got what I need.
