Hello everyone, I am kindly asking for help with a problem in copying DV cassettes.
I am using a Sony VX2000 with firewire output to a PC Windows 8.1 and WinDV for direct copy to PC.
For a few days now, some noise has appeared on the acquired videos, noise that was never present before - in the video file that I enclose you can see on the left the acquisition as it was before and on the right as it appears now: you can see some flickering lines in the coloured bands...
I also tried with other capture software ( ScenalYzer live, VLC, QuickTime,etc ) , I tried with various firewire cables and finally I tried with the capture on OSX : no result.
Could it be the firewire converter in the camcorder ..??
Thank you for your attention.
I'm puzzled to why you are getting chroma interference in a 100% digital workflow, This is usually a symptom of analog video capture over composite, Are you sure you have the original DV tapes not some dubbed copies and no analog is involved? and why the sample is WMV? Can you post few seconds of the original DV dump?
Hello dellsam34 and many thanks for Your help: indeed, the problem was caused by the recording on THAT DV cassette ,which was made with an analogue ( Y/C ) device resulting in noise on the video signal. In fact we tested it on another equipment and it gave the same defect.
Fortunately it does not depend on the camcorder!
Again thank you for your support and many greetings -
Ok, That explained it.
Steam Copy vs. Direct Stream Copy
By Sound Master in forum Newbie / General discussionsReplies: 15Last Post: 6th Apr 2024, 05:16 -
Copy My DVDs
By biferi in forum Newbie / General discussionsReplies: 21Last Post: 23rd Nov 2021, 17:55 -
Stream Copy or Direct Stream Copy?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2021, 21:03 -
DVD will not copy
By jarod1005 in forum Newbie / General discussionsReplies: 7Last Post: 31st Jul 2020, 11:14 -
Dvd copy
By Dave_55 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2020, 22:19
