Now I can batch process clips, thanks again, it gives me one more problem, namely a muddled folder full of original and processed clips. Mkdir produces a new folder, but how do I get ffmpeg to place its output in there please?
Add the desired path 'in front of' the output filename i.e.: C:\mypath\clip.mkv (windows) or /whatever/path/clip.mkv (linux)
Side to babiulep answer it will be good to add two additional steps - detection if required folder / directory exist and if not exist then create desired folder
creation of a new directory was used in that "scary" python script
bash script with simple relative directory path:
sometimes it is better to use absolute path, to work with absolute paths, if working directory is not the same as script etc. (not your case perhaps), then to get absolute path for you ffmpeg cmd:Code:#!/bin/bash DIR_NAME="new_709_files" mkdir -p ${DIR_NAME} #create that directory on disk if it does not exist for filename in *.mp4 do NAME=$(basename "${filename}" .mp4) OUTPUT_FILENAME="${DIR_NAME}/${NAME}.mp4" ffmpeg -y -i "${filename}" -c copy "${OUTPUT_FILENAME}" # example, it does nothing just copies mp4 to that new folder done
Code:#!/bin/bash DIR_NAME="new_709_files" mkdir -p ${DIR_NAME} #create that directory on disk ABSOLUTE_OUTPUT_DIR_NAME=$(cd ${DIR_NAME}; pwd) #creates absolute path for that new directory for filename in *.mp4 do NAME=$(basename "${filename}" .mp4) OUTPUT_FILENAME="${ABSOLUTE_OUTPUT_DIR_NAME}/${NAME}.mp4" ffmpeg -y -i "${filename}" -c copy "${OUTPUT_FILENAME}" done -
Thank you all. Once again, with a bit of patience and some tinkering, it works a treat.
I wish to apply and ffmpeg filter to many clips
By DeJay in forum LinuxReplies: 8Last Post: 4th Dec 2024, 05:15 -
How to feed output of ffmpeg into another ffmpeg filter?
By BosseB in forum Video ConversionReplies: 3Last Post: 27th Mar 2024, 13:53 -
How to prepare clips for ffmpeg merging
By vmackey in forum EditingReplies: 7Last Post: 17th Feb 2024, 18:53 -
How to normalize audio of an entire folder with MP4s (FFmpeg)
By Aorin in forum Newbie / General discussionsReplies: 0Last Post: 4th Jun 2020, 17:23 -
How can I Concatenate an entire folder with xfade+fade out? (FFMPEG)
By Aorin in forum Video ConversionReplies: 0Last Post: 22nd May 2020, 08:18
