Hi. I believe i was registered here many years ago, but had to create new account, so hi!
I have question about asiftware AV1 encoding performance while using Ryzen 7950x.
I "webripped" Pulp Fiction 3440x1440 using my rtx4070 in AV1 high quality, so recorded file had 12GB. My aim was to compare speed of rtx av1 encoding vs CPU speed ( file sizes, quality with this same bitrate ).
So my rtx4070 re-encode source file to ( again ) AV1 highest possible quality in 55mins ( it was approx 130-150fps )
With ryzen 7950x i used same settings, but 2-pass and standard quality "5" for AV1 (SVT ) encoder built in HandBrake and finally it took 5H:50mins, however - 1st pass was 180-200fps 100% CPU in use , where 2nd pass was jumping between 18-47-50 FPS with final average FPS 31, but i noticed CPU usage while 2-pass encoding in progress was between 25 to 50% ( all 16 cores/32threads in use ), jumping to 80-90% for very short time couple of times, i would say on average it was close to 50%... Is this something normal and it's just unoptimized encoder or some other reason/bottleneck etc ? It was using all cores/threads, however usage % for most of the time over 5h50mins stayed at 50%
Any ideas what could be cousing this ?
Thanks,
cts
Two pass encoders typically use fast, highly simplified settings for the first pass -- because all they are doing is generating information about how complex each shot is. The second pass is where the real work is done, so it takes much longer.
x264, x265, svt-hevc, svt-av1, shootout
By sophisticles in forum Video ConversionReplies: 21Last Post: 2nd Jan 2023, 09:39 -
Conversion error from 1080p to 720p with Svt-Av1
By ignace72 in forum LinuxReplies: 5Last Post: 6th Apr 2022, 14:16 -
What parameters to use to convert videos to av1 with SVT-AV1 with FFmpeg
By ignace72 in forum Video ConversionReplies: 4Last Post: 19th Mar 2022, 08:52 -
AOM adopts Intel SVT-AV1
By sophisticles in forum Latest Video NewsReplies: 2Last Post: 9th Sep 2020, 09:03 -
NetFlix to start using Intel's SVT-AV1
By sophisticles in forum Latest Video NewsReplies: 4Last Post: 8th Jan 2020, 08:12
