Hi.
I have a few videoclips captured from diferent sources am I want to make a svcd of them. The only problem is that audio volume differs to much between them (some are louder than others). My idea is to demultiplex to mp2 files normalize them and then re-multiplex them again. What I'm asking is if someone knows a program that can normalize the mp2 files directly without having to convert to wav and then to mp2 again therfore losing quality.
Thank you in advance.
Why not re-encode just the audio in TMPGEnc? That has an audio normalization function. You could also use it with an audio plugin such as TooLame or SCMPX. I don't know about quality loss, though.
I haven't found a good tool for this. TMPGenc does have a normalize function on its "Audio" filter in the "Advanced" tab on the settings panel, but like many simplistic audio editors it only allows you to state a multiplier, like normalize to 150% of the input stream's volume. This is because it doesn't scan for peak levels and then do the adjustment.
What you really want is to state a volume level, like normalize to 80% of the maximum, so that you can use the same number on all your mp2's. Still, you can use TMPGenc's normalizing to adjust the levels based on what you hear, then burn pairs of files to CD-RW's and repeat the process until you get them to match approximately.
On top of that, this filter only applies when you are encoding video! I think the latest TMPGenc version (2.54) moves this to the Audio tab, which may mean that you can encode the audio separately with normalization. Still, that's not going to help you skip making WAV's.
If anyone can recommend a program for this, it would be great. I saw somewhere (www.mpegx.com ?) that there is a GUI for toolame, but I'm pretty sure it's just another encoder and doesn't edit MP2's.
I have also heard good things about GoldWave, but have not gone to the trouble of downloading a trial version to see for myself. It's on www.mpegx.com under Audio Editors or Audio Utilities. -
I believe Besweet will normalize it, but I'm pretty sure it still does an internal mp2 -> wav -> mp2 conversion.
Originally Posted by burned_once
Originally Posted by burned_once -
Well there is a program out there called mp3Trim. You can search for it on google.com. It's a very basic program but it wiill scan through the file. If it wont load the mp2 file just rename it to .mp3 for the normalisation
most ppl say somethin smart or profound here.......... I won't -
Use soundforge5 as it opens up mp2 and has a normalize option that offers more than tmpgenc if you know what your doing you can really make it sound so much better(VHS captures).Soundforge 5 is a little expensive.........if you pay for it but it is an excellent sound editor.
Player that can play files burned directly from HD camcorder?
By mccake in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Dec 2011, 20:59 -
normalize video files
By bill40 in forum Newbie / General discussionsReplies: 10Last Post: 15th Jun 2011, 22:03 -
[Solved] How to normalize various wav files to same volume level?
By freebird73717 in forum AudioReplies: 3Last Post: 30th Sep 2009, 16:22 -
Playing ISO and VOB files directly to TV
By indiraider in forum DVD & Blu-ray PlayersReplies: 3Last Post: 13th Oct 2007, 00:29 -
normalize WMA files?
By gutsmanx in forum AudioReplies: 4Last Post: 11th Oct 2007, 17:49
