A well known issue is repeating patterns such as picket fences, window blinds, etc... cause problem from all video frame interpolation algorithms. There seems to be some improvement in this area... finally
EMA-VFI is a bit newer , and score slightly higher on benchmarks than RIFE
https://github.com/MCG-NJU/EMA-VFI
There are 4 EMA-VFI variants in InterpAny-Clearer (Along with 6 RIFE, 4 AMT, 4 IFRNet variants)
https://github.com/zzh-tech/InterpAny-Clearer
The EMA-VFI-DR variant tends to does better on "picket fence" sources that cause problems for other video frame interpolation algorithms like RIFE, DAIN, mvtools2, svpflow, Resolve OF, Adobe OF, etc...
3 Test clips which typically cause "freak out" artifacts from motion interpolation algorithms:
a) camera moving up with horizontal shutters, man partially occluding. Taken from "Fensterladen.mkv" courtesy of Selur
Test clip prep
EMA-VFI-DR result is clean. That practically never happens with this type of scene for video frame interpolation algorithmsCode:LWLibavVideoSource("Fensterladen.mkv") Crop(2,0,-14,0,true) Trim(40,97)
b) boy riding bike horizontally across vertical fence bars, camera tracking shot (black and white). Taken from The Bad Sister DVD
https://forum.videohelp.com/threads/397425-A-Thank-You-to-all-an-critiques-welcomed!#post2584649
Test clip prep
Preprocessed with TFM since src was field shifted. For EMA-VFI-DR You get some "smash face" (face looks punched in on interpolated frames), but overall the artifacts are much more palatable (especially at normal speed viewing) than the usual interpolation algorithms which have more distracting artifacts. There are still some minor artifacts with the default settings, increasing iterations to 4 (from default 2) seems to improve themCode:MPEG2Source("Picket Fence.demuxed.d2v") TFM(pp=0) Trim(3,0) #trim off duplicates Trim(0,25)
c) Selur fence clip. Girl riding bike in front of fence. Camera movement around.
https://forum.doom9.org/showthread.php?t=174541
Test clip prep
Original clip was a soft UHD. This was downscaled with ResampleHQ to 720p. The uneven curvature lens blur combined with "picket fence" tends to cause artifacts on the leading and trailing fence edges for most algorithms. EMA-VFI-DR has them to a lesser extent, but it blurs them slightly and it's more "calm" compared to other algorithms which freak out with distortions. Tests at higher resolutions produced worse artifacts for EMA-VFI-DR , maybe from those blur/lens distortion - or perhaps the training set data was not done at those resolutions - have to do more testing and on other clips an other motions like circular/diagonal.Code:LSmashVideoSource("forInterpolation.mp4") ResampleHQ(1280,720) Trim(0,75) #trim off last frame (black)
Another negative is the brake wire shadow on the pavement "flickers" more with EMA-VFI-DR compare to RIFE ; and RIFE is worse than mvtools2. The wire shadow gets reduced or blurred on interpolated frames .
Fensterladen.mkv and forInterpolation.mp4 are from selur's test clip for interpolation collection ( I hope it's ok to share this folder link selur)
https://drive.google.com/drive/folders/1hG4-vEDn4l_B0QTlsrUnyl8JrOAuRgBy
Comparison clips are slowed down
InterpAny-Clearer has some minor color/levels shifting and some legal range clipping for video inputs, possibly some YUV/RGB conversion issues. I reported issue at github.
This is a useful tool , especially for the specific repeating patterns/picket fence problem scenario during video frame interpolation. There are many video frame interpolation projects, but they are only marginally better or worse than RIFE. I'm hoping it gets a vapoursynth and eventually avisynth port of InterpAny-Clearer (Yes, I'm shouting out to: HolyWu, styler00dollar, WolframRhodium and others....)
	Thanks for the info!
	Sure, I posted the link back then, so others can use them to test interpolation methods.I hope it's ok to share this folder link selur
 Cu Selur
 Ps.: how well does EMA-VFI perform with the other clips?
 PPs.: here's an alternative link to the test files: https://drive.filejump.com/drive/s/3IjwAK2K2E2dfUPs0oX2wnpXv0cG3aLast edited by Selur; 3rd Dec 2024 at 14:37. users currently on my ignore list: deadrats, Stears555, marcorocchini
  "code":400,"error":true,"message" on http://getwvkeys.ccBy johnsonkiss in forum Video Streaming DownloadingReplies: 14Last Post: 25th Jul 2024, 22:45
  getwvkeys.cc code":400,"error":true,"message":"Failed to get license: 405By Koldunas in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2023, 03:44
  {"code": 2048, "message": "Authentication failed"} when getting licenseBy warmachine in forum Video Streaming DownloadingReplies: 2Last Post: 26th May 2023, 17:34
  How to change "m3u8" to "json" and "ts" to "js" extensionBy wowza in forum Newbie / General discussionsReplies: 6Last Post: 4th Mar 2023, 16:36
  How to change "m3u8" to "json" and "ts" to "js" extensionBy wowza in forum User guidesReplies: 6Last Post: 4th Mar 2023, 16:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
