Hello I know this question was asked before (some years ago) but it was never answered.
I'm using the Avidemux program to edit video clips.
I'm wondering if anyone knows if there is a way to save certain output settings on the left bar so that they are always the same when you open the program and edit?
I need certain output settings and it is annoying to have to set them each time.
Now standard (default) Mkv Muxer is selected, can this be changed to default mp4 Muxer?
It would be good to have these output things as default without needing to select them each time.
Thanks for any help.
Already found the answer to my question, sorry for posting previous question.
You set the settings you want, you do not need to load a video file to adjust these specific default settings.
Specific default settings adjustments = left screen adjustments.
Standard it's on Mkv Muxer, I changed this to mp4 muxer.
Then menu, edit, save current settings as default, and that's it.
This may be different if you're on another version, I don't know, but it should be somewhere in the menu.
From now on the default output format will be pointed towards mp4 and not Mkv
Hope this helps.
Avidemux (crop & resize) to output format MP4 Muxer (HEVC x265) - glitch
By mayazir in forum EditingReplies: 37Last Post: 31st Jan 2024, 00:16 -
avidemux queueing multiple files and folders with same output settings
By Windrider6 in forum Video ConversionReplies: 0Last Post: 7th Jun 2023, 01:40 -
PotPlayer - Where in the settings can you set a default playback resolution
By sluggerb in forum Software PlayingReplies: 8Last Post: 2nd Jun 2023, 13:49 -
Potplayer - How to set default video recording settings?
By itsZainBoi in forum Software PlayingReplies: 0Last Post: 13th Aug 2022, 17:57 -
Set a default subtitle track in a .mp4 file (with BOX4)
By Alice in forum SubtitleReplies: 1Last Post: 4th Oct 2020, 17:38
