I was messing around with TMPGENC and I tried encoding an MPEG 1 (in order to burn as a VCD in Nero) but I wanted the resolution to be 480 x 480 instead of the standard VCD size. I tried burning in nero as a non-standard VCD, and went to play it in my DVD player.
It played back at normal-speed video, distorted high-speed audio, and with green lines all over the picture.
I then opened the SVCD template in nero, dragged in the same MPG, and burned a non-standard SVCD. It worked perfectly in my DVD player!
So if anyone's having trouble with non-standard MPG's (I know people are using VBR to get long movies on 1 CD) try burning as an SVCD..
-Mark
Swim with me
And we'll escape
All the trouble
Of the present age
Finally free -
yes, it supports totally standard VCD's as well as seemingly anything i drag-and-burn into the SVCD template in nero
I've made standard SVCD's which play fine, too.
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
mpeg TS files works with no sound on sony vegas what i do/??
By khalid81 in forum EditingReplies: 11Last Post: 20th Jul 2009, 10:20 -
Audio works on DVD but not on its original MPEG-2 file
By tealgrey in forum MacReplies: 2Last Post: 15th Mar 2009, 14:32 -
DVD burning nightmares...it no longer works???
By apollo1980 in forum Authoring (DVD)Replies: 1Last Post: 27th Dec 2008, 16:22 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25
