Hi!
Hoping this might be a simple question for you guys to figure out. I have some old raw DV footage that was captured quite a while back from a Digital8 tape, but it appears every other frame is duplicated.
My goal is to edit it in Final Cut Pro (I'm on a Mac), and export it properly, but can't figure out what to do to get rid of the duplicated frames. I've tried all custom frame rates it lets you try and none of them get ride of duplicated frames.
Any clue what is up with these files? Here is the Mediainfo from the file:
Format : MPEG-4
Commercial name : DVCPRO
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 762 MiB
Duration : 3 min 29 s
Overall bit rate : 30.4 Mb/s
Frame rate : 29.970 FPS
Recorded date : 2005-10-28 21:09:44.000
Encoded date : 2012-03-06 23:04:08 UTC
Tagged date : 2012-03-06 23:07:38 UTC
Writing library : Apple QuickTime
com.apple.proapps.modelname : DCR-TRV110
com.apple.proapps.cameraID : 0x80046010176bec8
com.apple.proapps.cameraName : DCR-TRV110
com.apple.proapps.clipID : 2D85CD65-97A3-48B5-B616-CBB479403C60
com.apple.proapps.ingestDate.description : 2012-03-06 23:04:08 +0000
com.apple.proapps.originalFormat : DV/DVCPRO - NTSC (16:9)
com.apple.proapps.mediaRate : 30.000
com.apple.proapps.timecodeFormat : Drop
com.apple.quicktime.creationdate : 2005-10-28T21:09:44-0400
com.apple.quicktime.make : Apple
com.apple.quicktime.model : MacBookPro8,2
com.apple.quicktime.software : Mac OS X 10.7.3 (11D50)
Video
Format : DV
Codec ID : dvc
Source duration : 3 min 30 s
Bit rate mode : Constant
Bit rate : 24.4 Mb/s
Width : 720 pixels
Clean aperture width : 704 pixels
Height : 480 pixels
Clean aperture height : 480 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Clean aperture display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Original frame rate : 29.970 (29970/1000) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:1:1
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Interleaved fields
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:08:40;22
Time code source : Subcode time code
Stream size : 720 MiB (94%)
Source stream size : 720 MiB (95%)
Title : Core Media Video
Encoding settings : ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio #1
Format : PCM
Format settings : Little / Signed
Codec ID : sowt
Source duration : 3 min 29 s
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 38.4 MiB (5%)
Source stream size : 38.4 MiB (5%)
Title : Core Media Audio
Audio #2
Format : PCM
Format settings : Big / Signed
Muxing mode : DV
Muxing mode, more info : Muxed in Video #1
Bit depth : 16 bits
Other
Type : Time code
Format : QuickTime TC
Frame rate : 30.000 FPS
Time code of last frame : 00:12:10;20
Time code, stripped : No
Title : Core Media Time Code
Default : No
Results 1 to 16 of 16
"Every other frame" is not really a description I understand confidently. It does not really sound like typical Film/NTSC 2:3 Telecine pattern.
Are you able to show us a sequence of at least half a second with mostly straight horizontal motion? -
It says 29.97 fps (30000/1001). NTSC DV is always 29.97 fps, interlaced. If every other frame is a duplicate (AABBCCDDEE) the underlying frame rate is 14.99 fps (15000/1001). If you mean every 2nd frame is duplicated (ABBCDDEFF...) the frame rate is 19.98 (20000/1001). The latter is common for 8mm to video transfers.
Thanks for the reply!
Here is a 12 second clip. Careful, it's loud! (from an old basement gig)
https://we.tl/t-8Y7C5LZt5Dn
Thanks for any insight you might be able to give on this weirdness -
It also depends on how you are viewing it - if you're viewing it on a "60p" (60000/1001) timeline, it's actually 29.97fps (30000/1001) or "30p" progressive DV content if you have AABBCC...
I pasted a link to a short 12sec clip to look at earlier, but it's been waiting to be approved by a moderator, hopefully it will soon
To add to this, I just went back to the original tape and imported some clips from it fresh and the frames are also duplicated. I was hoping the old transfer was just weird and a fresh one would be all good... the mystery continues!
::Edit:: Here is the link, for anyone curious to inspect the clip (Be careful, it's loud!) : https://we.tl/t-8Y7C5LZt5DLast edited by StrangeMutant; 29th Nov 2024 at 19:22.
How did the D8 get transferred? what software and hardware were used? To me it looks like the transfer job was wrong.
I used a Sony TRV130 Camera with firewire cable to my MacBook Pro (Mid 2012 15"). I just tried importing direct to Final Cut Pro X and using Quicktime 7 Pro. Both give the same results.
PS, this is the same hardware/setup that I just used to import about 70 Digital8 tapes, and this is the only one of the bunch like thisLast edited by StrangeMutant; 29th Nov 2024 at 19:59.
In that case I start to believe this is 24p materials and encoded into DV as 30i, Or shot with a semi pro DV camcorder that had the option 24p in a scheme called progressive segmented frame (PsF), Basically it records interlaced fields from a progressive frame, The math doesn't add up however.
PSF should still give you a different frame on each frame step-thru, only the fields are duplicated. This has duplicated frames ie 4 repeated fields.Originally Posted by Dellsam34
The file you were inspecting was imported using an older TRV103 camera years ago, and I did a fresh transfer last evening using a borrowed TRV130 camera which gave the same results. It seems that this video is just going to have to stay the way it is.
Thank you all for looking at this weirdness! -
While the concept you are trying to express is clear and pertinent, a small clarification: in a PSF architecture the fields building the frame are not duplicated, because they contain the even (one) and odd (the other) scanlines, and then different. Their characteristic is that they are from the same moment in time, contrary to the interlaced video.
Thanks Lollo, point taken and understood. That explains why I could see very slight differences between the fields when I attempt to deinterlace a PSF video.
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 09:27 -
identify field order and frame type of VOB file with DGINdex
By RogerTango in forum DVD RippingReplies: 6Last Post: 12th Dec 2021, 12:06 -
Best Monitor Refresh Rate, OBS Frame Rate for streamed film movies?
By pmikep in forum Video Streaming DownloadingReplies: 10Last Post: 18th May 2021, 12:13 -
Video capture frame rate vs. final output file frame rate
By Theodore in forum Capturing and VCRReplies: 5Last Post: 18th Apr 2021, 18:48 -
Variabel frame rate / constant frame rate problem with free version of VSDC
By danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 03:50
