I am having trouble playing VCDs (.dat) on my computer. Windows Media Player does not work (give an error message that file format is not supported). I tried downloading the latest Windows Media Player & DirectX, but to no avail. What's nore, my friend using exactly the same Windows Media Player is able to play VCDs. Microsoft helpline informed me that since *.dat files are not supported by the Media Player, they do not guarantee that it will work, although it might. Can anyone help.
Just to make sure: You loaded WMP, clicked on "File" >>> "Open" >>> changed the extension to "all files" and chose your MPEGAV directory on your CD Drive? This works for most people.
However if this operation failed, I suggest using VCDGear (tools section of this website) and converting the dat to mpeg.
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 16:32 -
If a DVD/CD will only play on the computer...
By LellyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Sep 2010, 07:38 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 05:35 -
PVR 150 won't do VCD on new computer
By darwin-t in forum Capturing and VCRReplies: 9Last Post: 27th Mar 2008, 14:29
