Results 1 to 10 of 10
  1. Hello,
    I have the following problem. I would like to play a trailer in 4k before a UHD4K film disc. Both are available as BDMV/Certificate folders.
    How can I bring both films together so that the trailer is played first and then the film. I would like to burn the whole thing to disc and play it in the player. I am hoping for a simple solution without re-encoding. Thank you very much
    Oct 2007
    I have recorded all of my family videos on DVD and Blu-ray discs. It is much easier for family members to play then on a Blu-ray player then to have to put them on a flash drive.
    Oct 2007
    I replied to the wrong thread.
  4. Originally Posted by wolflop View Post
    Hello,
    You can concatenate files on tsMuxer with "join".
  5. Originally Posted by cibo View Post
    Hello,
    Does not work...
  6. Your reply is very unhelpful. I don't know what you have attempted exactly, and without details or indication of the error you got, then I can't help you any further.
  7. I tried to connect two Mp4 files but only one file was created. The first one I loaded. Is there exact manueal who to do withe mp4/mkv or iso ?
  8. MP4 files? But you said you had BDMV files availables of both?? The videos would be m2ts, with proper codecs and format. Why are you talking about mp4 and mkv now?
  9. I tried mkv and mp4 as an alternative because loading m2ts didn't work either. So first the m2ts trailer then on connect the second m2ts movie. but tsmuxer shows no reaction when connecting the second m2ts. So I made several attempts to connect files. Once with 2 mp4, or 2 mkvs or 2 m2ts. None of them worked. No reason, only the first file was played.
  10. "Show no reaction"
    What do you mean? Are both m2ts properly unencrypted? No such issue for me so you are doing something wrong.
    1) How are you testing the output?
    2) What do you see in tsMuxer GUI when you join files? Do they have the SAME video format and framerate?
    You need to say exactly what you are trying to do, I don't see your computer or your screen.
