I'm digitizing some old VHS tapes on a tight budget. These are off-air recordings I made years ago. I'm using a Toshiba SD-V280 for playback and connecting it via red/white/yellow RCA cables to a Cinevision RV4000 VCR/DVD recorder combo unit for recording. I've been very pleasantly surprised with the results, except for one recurrent problem...
During playback on the Toshiba, once in a while the brightness will drop out then return. I've attached a brief sample, heavily compressed to upload here. This has happened with a few tapes. When I play them back in the Cinevision's built-in VHS player, there's no brightness dropout. (I don't like to do a direct VHS to DVD dub on the Cinevision because the VCR portion has inferior sound and picture quality, but the DVD recordings through the line-in are great).
Could this be as simple as needing new RCA cables? Unfortunately, the Cinevision doesn't have an S-Video in, so that's not an option.
The dropout happens at the 5 second mark.
Thanks.
Yes the drop in brightness occurs at frame 326. I'm not sure which is the better capture, before or after frame 326. The earlier capture blows out on the player's white uniform while the later may verge on losing some shadow detail. But that's not your question.
I would definitely check or swap the RCA leads, making sure that each plug is fitted all the way onto the VCR and recorder's sockets. While watching the picture, gently wiggle the cable and plug. It can sometimes expose a bad connection.
Sometimes the sockets and plugs become tarnished and require a little cleaning or polishing to make for good electrical contact.
How to remove brightness flickering on old vhs videos?
By banaguitar in forum RestorationReplies: 4Last Post: 24th Aug 2024, 14:49 -
Potplayer/KMplayer contrast/brightness issue
By Theinvoker in forum Software PlayingReplies: 0Last Post: 18th Jun 2022, 05:25 -
VHS to DVD quality issue
By cinemakyle01 in forum Video ConversionReplies: 96Last Post: 19th Sep 2021, 16:34 -
Sync issue after converting VHS to DVD
By MollyMollz in forum AudioReplies: 7Last Post: 11th Dec 2020, 01:34 -
Brightness mess when capturing *some* VHS through Sony DCR-TRV33E
By trotskito in forum Capturing and VCRReplies: 32Last Post: 2nd Dec 2020, 17:02
