    Nov 2024
    São Paulo
    Hi guys
    I used to do create DVDs by converting m2v to video and AC3 to audio and authoring in dvdlabpro, but now I have a bluray drive on the way, and I'm confused about which elementary FHD file I can get without having to re-encode the file when creating the disk. At the moment I only know TMPGENC Authoring but the MP4 files are always re-encoded and take hours to convert. Can you recommend another program without re-encoding?
  2. Is this for SD blu ray ? You have a SD m2v for the DVD and DVDLabPro . Where does the MP4 come from ?
    The MP4 would only pass through if it was already BD compliant. If it used non-compliant encoding settings for BD, it needs to be re-encoded. That will happen with every BD authoring program - a non compliant source will get rejected
    Nov 2024
    São Paulo
    No, it's 1440x1080p video mp4 file, but 40mbps bitrate
  4. Originally Posted by PaulM2 View Post
    Where is the mp4 from ? e.g. camera etc..
    What does mediainfo (view=>text) say about the file ?
    There are a bunch of rules you have to follow for BD compliant streams, otherwise you don't get passthrough and it needs to be re-encoded for compliance
    For example if the MP4 didn't use VBV buffer settings, it might cause buffering issues such as over/under flows. This would be rejected
    1440x1080 for BD primary stream is only supported as 16:9 . A "square pixel" 4:3 is not supported and would need to be pillarboxed
    Nov 2024
    São Paulo
    General
    Complete name : C:\Users\PRB515\Downloads\01 - Force from the Future.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (mp42/mp41)
    File size : 1.99 GiB
    Duration : 21 min 24 s
    Overall bit rate : 13.3 Mb/s
    Frame rate : 29.970 FPS
    Encoded date : 2022-11-06 22:26:39 UTC
    Tagged date : 2022-11-06 22:27:08 UTC
    TIM : 00:00:00:00
    TSC : 30000
    TSZ : 1001
    Video
    Format : AVC
    Format profile : Main@L4.1
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Codec ID : avc1
    Bit rate : 13.0 Mb/s
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.278
    Stream size : 1.94 GiB (98%)
    Language : English
    Tagged date : 2022-11-06 22:26:39 UTC
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Source duration : 21 min 25 s
    Bit rate mode : Variable
    Bit rate : 317 kb/s
    Maximum bit rate : 386 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 48.6 MiB (2%)
    Source stream size : 48.6 MiB (2%)
    Language : English
  6. It has to be re-encoded for BD compliance
    1440x1080 4:3 content needs to be pillarboxed to 1920x1080 for BD primary streams
    Progressive 29.97 encoding is not compliant with BD - it needs to be encoded interlaced or mbaff
    AAC audio is not compliant - audio needs to be re-encoded
    Probably a bunch of other things not shown by mediainfo - such as no VBV settings , GOP length
  7. Yes, it's far away from BD specs compliance.
    FWIW here the video rules
    https://forum.doom9.org/showthread.php?t=154533
    And here the settings for compliant encoding using x264 encoder:
    http://web.archive.org/web/20211016213149/http://www.x264bluray.com/home/1080i-p
