Had a BSOD using my ATI 750USB when it died. Found a new one but noticed that there are no crossbar entries anymore. Tried putting it on another machine with a fresh install and had the same result.
I still have the ksxbar.ax file on the machine. What makes the crossbar entry appear? Is there something I can re-install to make it show up?
Results 1 to 9 of 9
Have you tried re-registering the ax file?
It's loaded as needed. If it doesn't show up in two different Windows builds of Windows 10/11
then something changed in those newer OS'
Don't have any further details, perhaps somebody else will chime in -
[QUOTE=doncaruana
It was working before the 750 died. No os changes after that, replaced 750,doesnt work anymore. That's what has me flummoxed.[/QUOTE]
What do you suspect - Is the second device bad?
Have you tried a capture in Virtualdub to see if it shows up ? -
Got it working on the "new" machine! On my original machine, I had done an upgrade from win7 at some point. And I found a post somewhere about installing in compatibility mode https://answers.microsoft.com/en-us/windows/forum/all/how-to-make-ati-tv-wonder-650-wo...4-25637f39feec
So I uninstalled the device (which showed up as a Cali TV Card) then I went to the CD, drilled down to the 64 bit folder for the drivers, set the setup to be XP sp3 compatibility and then ran the install as administrator. And voila!!
Looks to be working good on the new machine!
Haven't doubled back on my original yet and I might not anyway. It's my main machine and I don't like getting too "clever" with drivers and such. -
Hey congrats on the fix and the details, it will be helpful to others in the future
How to remove series entries.
By Mondriaan in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2024, 18:09 -
Seek Entries at End of MKV File Instead of at Start, Impossible to Navigate
By koberulz in forum Newbie / General discussionsReplies: 13Last Post: 30th Nov 2023, 20:02 -
Help with GraphStudio setup for capture
By VideoYak in forum Capturing and VCRReplies: 7Last Post: 9th Sep 2023, 10:02 -
Nero Video has hard limit on number of menu entries
By ravenswd in forum Authoring (DVD)Replies: 5Last Post: 17th Jan 2022, 05:46 -
CALL FOR ENTRIES San Francisco Green Film Festival 2020
By sfgreenfilmfes in forum Latest Video NewsReplies: 1Last Post: 3rd Feb 2020, 19:46
