Hello Guys,
I am trying to download a cartoon show from zee5.com from this url https://www.zee5.com/global/kids/kids-shows/bantul-the-great/0-6-231/bantul-the-great-...sode/0-1-74065. However if I try to access zee5 from Bangladesh, I get
.Access Denied
You don't have permission to access "http://www.zee5.com/global/kids/kids-shows/bantul-the-great/0-6-231/bantul-the-great-episode-185-february-1-2015-full-episode/0-1-74065" on this server.
Reference #18.d4a4d417.1732426509.b6f6b110
https://errors.edgesuite.net/18.d4a4d417.1732426509.b6f6b110
The site seems to work fine through vpn. Now how do I download this video?
Note: This cartoon called Batul the Great is my favourate childhood show andso it's very nostalgic. So I'm trying to archive the available episodes. This is just an example episode link. I am planning to download the whole series.
So, Any help is really appreciated. Hope you guys have a nice day.
Thanks in advance.![]()
Closed Thread
Results 1 to 10 of 10
I was able to download it using IDM. You can use a free VPN so it will not detect that you are from Bangladesh.
Proton VPN has free servers from few countries.
That is an option. But i am trying to automate downloading a few episodes. So that's out of the book. Otherwise i could just use yt-dlp.
The main problem is i want to automate the process. I could use yt-dlp if the site was not blocked in bangladesh or i could use playwright. but these are not practical in bangladesh. And through vpn the site is too too slow for any content to download. So i hope you understand the problem. Thanks.
poetry run python widefrog.py "https://www.zee5.com/global/kids/kids-shows/bantul-the-great/0-6-231/bantul-the-great-episode-185-february-1-2015-full-episode/0-1-74065" [INFO] Linux detected. Chosen terminal: xterm. Chosen shell: bash. [WARNING] The service cda.pl cannot be used because it is not properly implemented, has package errors or has syntax errors. After fixing the issue delete the app_files folder. [INFO] Current app version: 2.10.0 [INFO] Running on: linux/64bit/python 3.11.9 [INFO] Starting the service initialization stage. [INFO] Current progress: [1/1] [INFO] Starting the collections extraction stage. [INFO] Current progress: [1/1] [INFO] Starting the media data extraction stage. [USER_ERROR]/[APP_ERROR] Failed to download: https://www.zee5.com/global/kids/kids-shows/bantul-the-great/0-6-231/bantul-the-great-episode-185-february-1-2015-full-episode/0-1-74065. Reason: Failed to extract content data. Solution: Make sure you can play the content. If you can, then debug the zee5_com service. [INFO] Finished generating the download commands. [WARNING] Saved the failed URLs to app_files/cmds_failed.txt [WARNING] No download commands have been generated.
I'll fix the service in a next release. For now stick to simple downloading. Use stream detector, get the m3u8/mpd URL and use it with yt-dlp/N_m3u8DL-RE. Most sites enforce VPN only for accessing, not downloading.
HTTP 403 Access Denied (Binge)
By CrymanChen in forum Video Streaming DownloadingReplies: 27Last Post: 8th Aug 2024, 14:49 -
Zee5 video download
By Username_1 in forum Newbie / General discussionsReplies: 9Last Post: 9th Nov 2022, 03:47 -
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 21:28 -
403: (access denied) Error While Writing Zee5 Live Tv Using Ffmmeg
By StarkGang in forum Video Streaming DownloadingReplies: 1Last Post: 9th Jun 2021, 00:44 -
TMPGEnc Authoring works 4 - Access is Denied (Error code 0x80070005)
By The Roo in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2021, 17:34
