Got my hands on a low-effort pressing of an old serial on bluray. Quality of the individual frames is actually not bad. I can tell it probably really is something above NTSC. Unfortunately, everything about the actual bluray mastering is borked. For one thing, they stuffed 4 hours onto a single 25GB layer, and gave the entire video 10Mbps to work with, at a constant bitrate.
But the main problem is that they mastered it at 29.97fps which of course means 1080i with a temporal resolution of 59.94fps. (Actual scan type listed as MBAFF.) The final cadence is 2:2:2:4, or 1:1:1:2 depending on how you want to look at it.
I've tried tinkering with ffmpeg's mpdecimate function, and while I can get a result that does whittle it down to 24fps, it also discards every sequence of frames that are duplicate, even when they are things like static digital title cards, and I can't seem to pin down thresholds that sidestep this result. Though it would be better if there were a function that was designed to assume a steady cadence for the entire video rather than proactively hunting for that cadence every frame.
Suggestions?
The regular decimate filter should work for that.
https://ffmpeg.org/ffmpeg-filters.html#decimate-1 -
Does seem to work, at least for a test snippet. Knock on wood.
Since I'm having to re-compress the video anyway, I want to get the best quality out of the result that I can. In your opinion, what would be the best codec/preset/whatever to go with? It's fairly grainy black and white film.
how 2 modify the ending and starting points of a subtitle line in Aegisub??
By SubtitlerGuy in forum SubtitleReplies: 0Last Post: 11th Jul 2024, 00:33 -
help needed-project ending with errors
By tyson25 in forum Authoring (DVD)Replies: 5Last Post: 19th Jul 2022, 16:07 -
Proper cadence terminology for progressive-only rate downconversion?
By joema in forum Video ConversionReplies: 12Last Post: 4th Jul 2022, 20:26 -
Is there an easy way to find broken cadence in 2:3 pulldown of TS files?
By Ronstang in forum Video ConversionReplies: 19Last Post: 1st Feb 2022, 14:21 -
Video Ending Transition using transparency in VSDC help
By solidMGSsnake in forum Newbie / General discussionsReplies: 0Last Post: 21st May 2020, 00:33
