I'm not sure if this is the correct place to post this question but here goes. I tried to register on the Avidemux Forum but keep getting a message that I cannot register. Never had this happen when registering for other forums, including this one. Can anyone tell me if they are no longer accepting new forum members. Also, the question I wanted to ask there is about a new update that that keeps displaying when I turn on my computer. It says Setup Avidemux VC++64bit. In the setup window, there are three choices: Add or remove components, Update components, and Remove all components. Remove all components is select by default. You must select one of these to continue. I have no idea which one to select. If I select anything other then Remove all components, I get another window that want to know where to set things up. Anyone know about this message and what I'm supposed to do? Thank you very much for your help.
Results 1 to 1 of 1
Avidemux audio conversion question
By sycor in forum AudioReplies: 3Last Post: 12th Nov 2025, 17:11 -
download file from jfc.org.il
By gurmurad in forum Video Streaming DownloadingReplies: 7Last Post: 31st Aug 2023, 16:32 -
AVIDEMUX question
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 8th Feb 2023, 15:45 -
New to forum, question about virtual backgrounds w/green screen
By sethym in forum Newbie / General discussionsReplies: 22Last Post: 26th Feb 2022, 22:15 -
Can somebody help with locast.org ts files?
By lajvguy in forum Video Streaming DownloadingReplies: 13Last Post: 24th Jan 2020, 15:02
