Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 63
    Mar 2024
    Yes unfortunately, although @TPD94 looks to be bringing cdm-project.com back online...
    Try the following provided by @phased for now:
    https://files.videohelp.com/u/312095/devine-services.zip
  2. Code:
      File "C:\devine\devine\core\utilities.py", line 84, in import_module_by_path
        spec.loader.exec_module(module)
      File "C:\devine-services\services\HULU\__init__.py", line 9, in <module>
        from devine.core.utils.pyhulu import Device, HuluClient
      File "C:\devine\devine\core\utils\pyhulu.py", line 6, in <module>
        import pyhulu
    ModuleNotFoundError: No module named 'pyhulu'
    The following error is appearing for me, I have the pyhulu.py file in the folder indicated by the error, and yet it doesn't find anything.
    Mar 2024
    Hulu is not a free to air service and also isn't part of the services included in my guide.
  4. Originally Posted by SaintyUK View Post
    I solved the error by deleting the unnecessary folders, and now it's working properly. I was using a services folder that someone had sent me, it had unnecessary folders.
  5. Thank you SaintyUK for making this guide and thank you stabbedbybrick for making this Devine fork. I have been waffling about spending the money to get another mini pc but if I do that; I will definitely give this a try.
    Jan 2025
    England
    I'm trying to get devine to use a proxy for some services, but I can't figure out the syntax for the devine.yaml file, or make --proxy work. I've got a NordVP account, so I probably need to put the details somewhere and then I need to tell devine to use a proxy for a particular service.
    Anybody made this work?
    I should say that devine is in general very easy to use, and I can get round the problem by setting my computer to the right country, but that's a bit inflexible.
    dwk33
  7. EDIT
    Solved, reran installer and checked "Add Python to environment variables". I did this manually and restarted the CMD window but it didn't work still. Somehow it did after rerunning the installer. I love windows!
    EDIT2
    All setup now, many thanks for the guide SaintyUK
    Hi, thanks for the guide, I'm on W10 and get stuck at this bit. Python installed successfully I used all the defaults but when I execute this commend "C:\devine>python.exe -m pip install --upgrade pip" I get this error
    Python was not found; run without arguments to install from the Microsoft Store, or disable this shortcut from Settings > Apps > Advanced app settings > App execution aliases.
    So I disabled the app aliases then get
    'python.exe' is not recognized as an internal or external command,
    operable program or batch file.
    So python can't be found even though it's installed, how do I fix that?
    Heads up this link has changed "https://www.gyan.dev/ffmpeg/builds/packages/ffmpeg-7.1-essentials_build.zip".
    Thanks.
  8. Originally Posted by SaintyUK View Post
    Overview
    The following is a semi-automated guide to install stabbedbybrick's fork of Devine, any dependencies and stabbedbybrick's Devine services!
    The fork has these added features:
    • Adds N_m3u8DL-RE as a downloader
    • Download audio and video tracks directly instead of via a proxy
    (see full changelog here)
    This guide assumes a few things:
    • OS is Windows 11 24H2
    • Python is not already installed
    • Git is not already installed
    • Required binaries will be downloaded to C:\devine-bin
    • Devine will be downloaded to C:\devine
    • Devine services will be downloaded to C:\devine-services
    If any of these are not true, please proceed with caution.
    1. Python Installation
    Note: Python 3.13.0 support is not available at the time of posting this guide
    1. Open a new Command Prompt (cmd.exe) instance
    2. Download the 3.12.7 64-bit Windows installer release of Python:
      curl -L -O https://www.python.org/ftp/python/3.12.7/python-3.12.7-amd64.exe
    3. Execute the following:
      python-3.12.7-amd64.exe /passive PrependPath=1 Include_tcltk=0 Include_test=0
    2. Git Installation
    1. Download the latest 64-bit version of git from: https://git-scm.com/downloads/win
    2. Install - accept all the default options if you are unsure
    3. Other Binary Dependencies
    1. Execute the following:
      mkdir C:\devine-bin && cd C:\devine-bin
      curl -L -O https://github.com/shaka-project/shaka-packager/releases/download/v2.6.1/packager-win-x64.exe
      curl -L -O https://www.gyan.dev/ffmpeg/builds/packages/ffmpeg-7.1-essentials_build.zip
      tar -x -f ffmpeg-7.1-essentials_build.zip ffmpeg-7.1-essentials_build/bin
      move ffmpeg-7.1-essentials_build\bin\* . && rmdir /S /Q ffmpeg-7.1-essentials_build && del ffmpeg-7.1-essentials_build.zip
      curl -L -O https://github.com/nilaoda/N_m3u8DL-RE/releases/download/v0.2.1-beta/N_m3u8DL-RE_Beta_win-x64_20240828.zip
      tar -x -f N_m3u8DL-RE_Beta_win-x64_20240828.zip
      move N_m3u8DL-RE_Beta_win-x64\N_m3u8DL-RE.exe . && rmdir /S /Q N_m3u8DL-RE_Beta_win-x64 && del N_m3u8DL-RE_Beta_win-x64_20240828.zip
      curl -L -O https://mkvtoolnix.download/windows/releases/87.0/mkvtoolnix-64-bit-87.0.7z
      tar -x -f mkvtoolnix-64-bit-87.0.7z mkvtoolnix/mkvmerge.exe
      move mkvtoolnix\mkvmerge.exe . && rmdir /S /Q mkvtoolnix && del mkvtoolnix-64-bit-87.0.7z
      curl -L -O https://github.com/CCExtractor/ccextractor/releases/download/v0.93/CCExtractor.msi
      msiexec /a CCExtractor.msi TARGETDIR="C:\devine-bin\ccextractor_temp" /q
      move ccextractor_temp\PFiles\CCExtractor . && rmdir ccextractor_temp /S /Q && del CCExtractor.msi
    4. Devine Installation
    2. Execute the following:
      mkdir C:\devine
      git clone https://github.com/stabbedbybrick/devine.git C:\devine
      cd C:\devine
      git checkout n_m3u8dl_re
      pip install --upgrade setuptools
      pip install poetry
      python -m venv venv
      venv\Scripts\activate.bat
      poetry config virtualenvs.in-project true
      poetry install
    5. Devine Services Installation
      mkdir C:\devine-services
      git clone https://cdm-project.com/stabbedbybrick/devine-services.git C:\devine-services
    6. Configure Devine
      mkdir %LOCALAPPDATA%\devine\WVDs
    2. Add your Widevine Device (.wvd) file to this directory - not covered in this guide. Information is readily available elsewhere in this forum!
    3. Execute the following to create a new config file:
      notepad %LOCALAPPDATA%\devine\devine.yaml
    4. Add the following lines to the config file, replacing {} with the correct values:
      directories:
        services: C:\devine-services\services
      credentials:
        ALL4: {ALL4 USERNAME}:{ALL4 PASSWORD}
      cdm:
        default: {NAME OF WVD FILE WITHOUT EXTENSION}
      downloader: n_m3u8dl_re
      n_m3u8dl_re:
        use_proxy: false
      dl:
        workers: 16
        sub_format: srt
    7. Final Steps
    1. Add binary directories to the user path. Execute the following:
      for /f "usebackq tokens=2,*" %A in (`reg query HKCU\Environment /v PATH`) do set USER_PATH=%B
      setx PATH "C:\devine-bin;C:\devine-bin\CCExtractor;%USER_PATH%"
    2. Create a user friendly shortcut. Execute the following:
      echo @echo off > "%LOCALAPPDATA%\Programs\Python\Python312\Scripts\devine.bat"
      echo C:\devine\venv\Scripts\python.exe C:\devine\venv\Scripts\devine %* >> "%LOCALAPPDATA%\Programs\Python\Python312\Scripts\devine.bat"
    8. Test
    2. Test the install by downloading an episode of Gogglebox from the ALL4 service:
      devine dl -w S24E10 all4 gogglebox
    3. Once completed. The video file (mkv) should be in a directory in %USERPROFILE%\Downloads\devine\
    Thanks to @pssh for the previous guides - used as a basis for the above!
    And finally a special thanks to @stabbedbybrick for the devine fork and of course all the services!
    I am step 6 Configuring Devine and when I input the code to activate the .yaml, Notepad says "The system cannot find the path specified". Please I need some guidance as I do want to get this set up. Thank you in advance for any help given.
    Hopefully I am not far off the mark; Devine Env Info has quite a list but says the config file is missing but gives me directions on where it can go.
    Jan 2025
    England
    My yaml file is at C:\Users\<username>\AppData\Local\devine, and I didn't change the defaults.
    That's also the same as notepad %LOCALAPPDATA%\devine\devine.yaml, so it should work!
    From the command line, type: dir *.yaml /s
    If that doesn't work, the installation has failed somewhere. But I thought from earlier posts, you'd got devine running!
    P.S. I still don't know how to configure NordVPN proxies in my yaml file
  10. Originally Posted by dwk33 View Post
    On my first Mini PC I have Devine working. I bought a newer Mini PC and I wanted to get this Devine Fork up and running. I have had a look through this install and all the folders are there and I did have a problem with WVD but eventually that folder showed up. I have never been able to get Proxies figured out. I am going to give what you wrote a try. Thank you for your response.
  11. I just created a devine.yaml from scratch and devine env info still says no .yaml exists. I have it in the correct folder.
  12. I have got a .yaml made that devine env info is pointing to now. The poster who made OzVine answered a question about .yaml in the GitHub Forum for Devine and I worked with what he wrote and also I was confused as despite myself thinking I had the .yaml in the correct folder I didn't. I am off to test it now and hopefully it works. If it does work thanks for the guide and this will be the quickest I ever got Devine set up correctly but the proof is the testing so we shall see. I have to get some cookies set up for certain services I haven't done that yet.
    Jan 2025
    England
    Good - if you figure out how to do a direct message, contact me, and we'll fix any remaining problems, but perhaps not proxies
  14. Major confusion file folders which Devine env info shows exist don't exist. CDM failing; my brain hurts so I have to call it quits for today. Several different Devine Folders.
  15. Thank you for the guide and I finally got Devine set up on my new mini pc. I did the test and Devine launched a proxy and it seemed to be failing then I shut off my VPN then it started working. Then it said it was ffprobe, so I dropped that into the bin folder. Then I tried the test again and it said it was missing ffmpeg so I put that in that folder. Then I tried again and it loaded the CDM and it worked.
  16. Hi all,
    Apologies if this is a stupid question - I hope not. Am I doing something daft here? Everything I try to download from ITV always ends in "exception occurred in Service's licence function"
    For example:
    devine dl ITV "https://www.itv.com/watch/thunderbirds-are-go/2a2131/2a2131a0007"
    [Attachment 87629 - Click to enlarge]
    I've tried debugging my way through the code but I'm new to Python so Devine is still above my pay grade.
    Any advice very much appreciated !
    Jan 2025
    England
    How did you configure your proxy to get devine to launch a proxy? I'm wondering if it's related to configuring NordVPM.
    dwk33
  18. Member
    Jan 2025
    England
    Originally Posted by jimmythepom View Post
    Hi all,
    For example:
    I can download BBC programmes but ITV doesn't want to play. I'm getting a different error:
    "devine dl -w s1e1 itv https://www.itv.com/watch/code-of-silence/10a5340" gives
    Retrying (Retry(total=8, connect=None, read=None, redirect=None,
    status=None)) after connection broken by 'RemoteDisconnected('Remote
    end closed connection without response')':
    ALL4 is no better.
  19. Originally Posted by dwk33 View Post
    dwk33
    Well I gave up Devine for a bit and set about trying to install and set up Angela's UKTV Downloader and I was using a guide by PSSH and then it seemed to be failing and I gave up on it. Then I returned to this Devine set up and finally it worked. Then the surprise Hola Proxy sprung up and I could see that wasn't getting anywhere and then I thought shut off the VPN and then it did its thing. It was by accident but perhaps someone else here can explain what happened.
  20. Now Devine hangs on: checking if current region is geoblocked
    Hola has launched and set to GB from this command line:
    devine dl --list-titles ALL4 https://www.channel4.com/programmes/the-blacklist
    Whatever I have done to screw it up I do not know.
  21. I did a search in Windows for hola and it showed there was a hola-proxy.exe in the system 32 folder so I took that and transferred that to a thumb drive. Now I have activated my VPN and set it to a U.S. City and Devine is downloading an episode at the moment. Update it got the first episode of what I was trying to get so the hola freeze up is gone.
  22. Member
    Jan 2025
    England
    I haven't got a hola freeze, but ITV is no better. Does ITV work for you? My system is still stuck on "Fetching Title Metadata..."
  23. Since I got rid of that hola.exe file Devine is working fine and I have tested ITV with an episode of "Vincent" and it turned out fine with the exception the video is totally surrounded by a black pillow box. VLC won't crop it out while playing it so I would have to crop it with Vidcoder and thus lose quality in re-encoding but that has nothing to do with Devine. Thankfully another show and an episode didn't have this type of thing. So thankfully everything is working with the exception of iP as far as I know as I haven't tested every service yet.
  24. Is anyone having a problem with TUBI? I noticed today it was downloading a movie and it got the audio and subtitles but seemed to hang on the video?
  25. Member
    Dec 2021
    england
    work on my machine
    [Attachment 87694 - Click to enlarge]
    I use expressvpn, may be it your vpn problem
  26. Originally Posted by iamghost View Post
    work on my machine
    Thank you for your response. It is nice to see it is working well for you. Usually I can get Tubi TV videos with WidevineProxy 2 without subtitles or chapters. I hope that keeps working out.
    I have Windscribe VPN that is part of Eset Security Ultimate. But it does have its limitations and it works better than Nord VPN. I will keep trying with Windscribe for the time being and I don't really want to move away from this Eset as I bought it at Best Buy Canada at a good price and only Best Buy has my Credit Card information. I did get Tubedigger and it is useful and I bought that because I purchased a Visa Prepaid Gift Card from the local Canada Post as I don't want very many vendors with my Credit Card info. So I will just make do and when one has a small income one can't just keep getting more VPNs. Just archive what you can and be grateful for what you have.
  27. Thankfully Tubi has been working again for me at least last time I was using it anyway.
  28. This tidbit may be of use to someone. I had a failed download and it said " [WinError 32] The process cannot access the file because it is
    being used by another process:" then it gave the location of the elusive temp folder for Devine in this fork: It is the Users/YOUR USER NAME/AppData/Local/Temp which has a Devine folder within it. I find that sometimes these Temp folders build up with failed downloads so it may be of use to delete the files if they are of no use to free up hard drive space.
  29. When trying to execute the command to get the stabbedbybrick repository, it returns the error:-
    remote: Repository not found.
    fatal: repository 'https://github.com/stabbedbybrick/devine.git/' not found
    Has this been removed by the author and therefore no longer available?
    Any information would be appreciated, cheers.
  30. Member
    Mar 2024
    It would seem so.
    I'd suggest looking into unshackle instead now.
