i've used makemkv to rip files on one laptop (lg gram) with no issues. i put the software on another laptop (lenovo thinkpad) and the ripped file has no sound. for some reason, if i run the ripped file through video.net, it shows as having an audio track, but there is no sound on the resulting file.
anybody?
thanks up front.
forgot to mention (if applicable) that both machines have windows 10.
Probably original computer has codec supporting sound stream's format, while 2nd computer doesn't. Easy to see what the format is: check file in MediaInfo.
To see about codecs, you will have to see what you've installed, and know which architecture the app used is relying upon (e.g. DirectShow, MediaFoundation, ffmpeg...)
Scott -
ISO External Blu-Ray (or 4k blu-ray) burner drive for PC (Windows 11)
By derricomonico in forum Blu-ray RippingReplies: 3Last Post: 16th Sep 2024, 17:16 -
Blu-Ray Sound Gets Out of Sync when Played Back on Disk Player
By Philip White in forum Video ConversionReplies: 2Last Post: 19th Apr 2021, 21:55 -
No sound on Blu Ray after burning
By Loplop in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Nov 2020, 13:25 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 13:02 -
Having trouble adding Atmos sound to 3D Blu-Ray
By smd9 in forum Blu-ray RippingReplies: 24Last Post: 4th Apr 2020, 00:45
