Hello,
I'm new to VirtualDub and I've been using it to touch up old VHS captures. I like the filters and am pleased with the results. However, I need to export the video to MPEG-2 or MPEG-4. Exporting to an uncompressed AVI filed just isn't feasible due to the file size. What is the best way to do this?
Thanks.
VirtualDub has a frame server. It also supports external command-line encoders.
"Programmers are human-shaped machines that transform alcohol into bugs." -
Use VirtualDub2. It can directly export to MPEG 4 (ffmpeg, xvid) or more modern codecs like h.264 (AVC) and h.265 (HEVC).
Above answers are correct but you can also export your framework using compression - just select desired codec, set desired compression parameters and start exporting.
Export a frame as jpg in virtualdub
By tat in forum EditingReplies: 3Last Post: 15th May 2023, 00:10 -
By Anonymous84 in forum EditingReplies: 1Last Post: 5th Feb 2023, 00:35 -
Virtualdub export image sequence "Access is denied"
By ecc in forum Video ConversionReplies: 5Last Post: 6th Jul 2020, 09:43 -
VirtualDub 4K Export
By jseo13579 in forum EditingReplies: 3Last Post: 21st Apr 2020, 11:50 -
Solved: MPEG-1 and MPEG-2 deinterlacing with VapourSynth - Help
By PRAGMA in forum DVD RippingReplies: 0Last Post: 1st Jan 2020, 10:23
