Hey guys......I just converted spiderman cd's 2 and 3......but the problem was that there was no audio..so I took the audio from the svcd files converted themm into wav then converted them with TMPGENC..now I need to know how to join the audio of two seperate cd's..cuz when I converted the last 2 cd's of spiderman they were both join..so instead of 2 different mpeg files there's only one..........so now I need to know how to join the two seperate audio files together so that I can multiplex them with the mpeg.....do u know of a program that will do that.....thx
TMPGenc will do it using the MPEG Tools menu item and select Simple Multiplex. Choose the type, e.g. MPEG1 VCD, browse to your video and audio files separately, decide on the output file name and hit Run.
audio problem when converting
By Stevex70 in forum Video ConversionReplies: 0Last Post: 25th Mar 2011, 14:56 -
Converting tv shows audio
By Oem in forum AudioReplies: 3Last Post: 1st Feb 2010, 21:42 -
No Audio after converting
By Seff7845 in forum AudioReplies: 1Last Post: 30th Sep 2009, 04:52 -
No audio converting flv
By holywoodhawk in forum Video ConversionReplies: 0Last Post: 11th Aug 2009, 22:38 -
Converting audio with glitch
By koberulz in forum Newbie / General discussionsReplies: 28Last Post: 7th Sep 2007, 04:55
