I was under the impression that the option "Add files as additional parts" would overlay the files over each other. However, that does not appear to be the case. I am trying to execute a workaround L-cut with the last two Lord of the Rings films. As Disc 1 of each film has audio that should overlap onto the second discs if they were one movie/file. I have all the parts cut up as needed, I just need to overlay the .MKA audio file from the last 5 seconds of disc 1 onto the beginning of disc 2. Then, I can append that file with the edit of disc 1. However, when I use "Add files as additional parts", that segment does not seem to be present in the audio tracks. Wondering if anyone has any advice.
See this, it doesn't work the way you're thinking
https://gitlab.com/mbunkus/mkvtoolnix/-/wikis/Adding-files-vs.-Appending-files-vs.-add...4b0154d79446a9
Add Subtitle Tracks and Audio Tracks to Videos
By Jay123210599 in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2023, 18:49 -
Mkvtoolnix
By fits79 in forum Video ConversionReplies: 11Last Post: 28th Jul 2022, 12:24 -
MKVToolNix
By forsure in forum EditingReplies: 8Last Post: 14th Mar 2021, 11:19 -
mkvtoolnix
By vega69-ux in forum EditingReplies: 3Last Post: 25th Sep 2020, 20:54 -
mkvtoolnix how to enable/disable a selection of tracks?
By gendalv in forum EditingReplies: 4Last Post: 22nd Sep 2020, 02:36
