Hello All. I'm very new to the art of DVD.
I have "come upon" various .mkv files from the internet that I would like to burn to a dvd so that I can watch them on tv's. This has turned out to be much more difficult than I anticipated.
- I would like the format and disc type to be widely compatible with non-PC drives/players
- Most of the .mkv files are 6-8gb
Before I describe my journey, it might be best if you just suggest the simplest route to success.
Journey: I started with DVD+RW (4.7gb). This wasn't large enough for most of my .mkv files. So I used Lossless Cut to snip them in half. Then I learned about MPEG-2. I used Lossless Cut to export various mpeg types to no avail, and I tried Filestar for conversions as well. I got some DVD+R DL because of the 8.5gb capacity, hoping this would simplify my plight. Then I cooked my brain reading into codecs, video formats, etc. Then I learned about X-Box consoles varying file compatibility (thus giving me false negatives?), so now i'm only using my dvd player. Then I learned about .VOB. I'm chasing my tail. Please halp :')
@davexnet that's a valuable resource indeed. I spent a good while reading that before posting. While I have a better idea of what may work, I still have questions. I've already spent a lot of time and some resources trying do this so I consider my 'due diligence' paid- enough to consult the community before I go further.
I don't know how old your TV's are but did you consider/investigate the possibility to play the videos directly on your TV?
Using a USB storage, media player or something of a DLNA server, it would save you so much hassle of endless converting.
I have here a "old" Samsung TV from 2014, it can play quite a lot of formats.
No h265/HEVC but then most "MKV scene" files are still released as H264 format.
But then again, you can have your reasons to still want to make DVD's of course.
Was "Route 66" audio high quality for the era?
By brassplyer in forum AudioReplies: 1Last Post: 15th Mar 2023, 07:36 -
Converting VHS to Digital which route should I go for better quality?
By bigbadben in forum Newbie / General discussionsReplies: 22Last Post: 7th Nov 2021, 07:34 -
Win XP: Route audio input of soundcard to speakers of same soundcard
By sdsumike619 in forum ComputerReplies: 13Last Post: 16th Sep 2021, 16:54 -
using ffmpeg to convert a mkv or mp4 to MPEG-4 suitable for a DVD player
By NeilTelford in forum Video ConversionReplies: 5Last Post: 3rd Jun 2021, 10:55 -
Simplest software for playing & recording simultaneous
By BillPeet in forum Newbie / General discussionsReplies: 3Last Post: 15th May 2020, 20:10
