Hello
When I record with AmarecTV I first turn on the record button and wait about 15 seconds before I press play on the 8mm camcorder.
However, when comparing the tapes with the digitized result (Lagarith) I notice that there are still several seconds missing from the beginning of the tape.
Why is this happening?
Is there a setting I might have missed?
Do you experience this problem and how do you address it?
wait about 15 seconds before I turn on the 8mm camcorder.
I never experienced that, but I normally start a capture while the device is playing a blank section of the tape at the beginning of a recording. I will remove the unwanted noisy blank portion in post processing.
Just few seconds. I see the "noise pattern" in the preview windows, count a couple of seconds, and start capturing before the real recorded video arrives.
When possible I disable all NR features in the players and denoise in post-processing, which is more effective and produces more qualitative results.
How to use Amarectv Live
By Hamilthon in forum ComputerReplies: 3Last Post: 9th Jul 2024, 13:14 -
OBS vs AmarecTV
By techmot in forum Capturing and VCRReplies: 1Last Post: 26th Oct 2023, 08:32 -
Canon HF100 - doesn't record sound from external microphone
By AlexNRW in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Feb 2021, 13:23 -
AmarecTV Error
By ElmoRocks05 in forum Capturing and VCRReplies: 0Last Post: 6th Jul 2020, 17:46 -
Problem with AmaRecTV: Unable to record
By DreamyQuiet258 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2020, 12:07
