Hello, friends.
I have a video with frame-blending with a random pattern that I want to fix, however, all the filters for this purpose did not give results that satisfied me. Soon I intend to fix it manually, but I need a mask capable of finding the frames.
my idea is to use something similar to what I use for frame-comb:
then take the written frames and add it to avspmod as bookmarks and check manually, and then, use replace-frames (next/previous) to replace the bad frame with one of equal value.Code:CombMask2(cthresh=4, mthresh=1, chroma=true, expand=true, metric=0) WriteFileIf("G:\path\LOG.txt", "AverageLuma() > 1.0", "current_frame")
but I'm stuck finding a mask that can replace the combmask for this task.
Is there a mask that can detect and show scenes with frame blending like in the images/video below?
https://files.catbox.moe/zlq10z.mp4
[Attachment 83427 - Click to enlarge]
Furthermore, I appreciate your time in helping me.![]()
Results 1 to 1 of 1
How to improve chances of SRestore blend detection?
By ndjamena in forum Video ConversionReplies: 52Last Post: 7th Aug 2025, 14:30 -
VHS videos appear to be damaged - can only deinterlace with blend
By Ferrari420 in forum Newbie / General discussionsReplies: 40Last Post: 8th Jan 2024, 03:33 -
Which AviSynth plugin(s) can do this blend reversing operation?
By StevenGuy in forum RestorationReplies: 18Last Post: 6th Sep 2021, 20:55 -
30p > 20p then blend removal possible?
By domb84 in forum RestorationReplies: 3Last Post: 21st Aug 2021, 14:19 -
Undo blend-deinterlace?
By embis2003 in forum Video ConversionReplies: 4Last Post: 10th Oct 2020, 19:24
