My 8mm tapes (using an DCR-TRV240E) have white transparent flickering blocks, visible both on the camcorder's LCD screen and on the capture. What could be the reason for this?
Not all parts of the videos has these types of bands, but some clips have them.
https://youtu.be/Zih4ujQlFtI
https://www.youtube.com/watch?v=IBgOL_Z5Zfc
	It may be ralated to the tape itself and its recorded content. Try to disable all features of the camcorder (TBC, Noise Reduction) and expertiment what happens. Also try another player if possible.
	@jokris: There is a chance that only 1 field is poor and the other field is intact (or better). You can check by separating and inspecting the fields. Or upload the snippet with the stairs here so someone can take a look.
	If anyone would like to take a look at it:
 https://drive.google.com/file/d/1nV5AeImOrPfhstBSpjEDQnKO3upVtzV-/view?usp=drivesdk
  white full frame flicker every other frame, Mad VR 205 ok, 206 not okBy Nicholas Steel in forum Software PlayingReplies: 1Last Post: 7th Aug 2024, 15:36
  Removing vids with transparent/semi-transparent watermarksBy JadHC in forum RestorationReplies: 22Last Post: 6th Jan 2024, 06:43
  8mm digitalization - Picture is either blinking or black and whiteBy ther89 in forum Capturing and VCRReplies: 10Last Post: 1st Feb 2022, 06:26
  Original file in mp4 format from Reflecta 8mm Super 8mm scannerBy Sajmon in forum RestorationReplies: 0Last Post: 27th Feb 2021, 12:56
  TRV120 D8 cam won't play most old 8mm tapes, any recommended 8mm camcordersBy analog2digital in forum Capturing and VCRReplies: 1Last Post: 22nd Feb 2020, 12:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
