Results 1 to 11 of 11
    Mar 2023
    Australia
    Using a USA VPN to access https://www.foxsports.com/replays and in the past I was able just use stream detector to grab the N_m3u8dl-RE link and download a game. If you don't have a TV provider they have a preview which is generally enough to grab the link and get out. I believe they have now inserted ads and after an extremely long time using N_m3u8dl-RE downloading a 4gb file all I got was ads. I also tried with IDM but that said can't download blah blah.
    Could anyone offer some insight as to how I can download some files please
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Video URL? What's the one that gives you problems?
  3. Banned
    Jun 2024
    Originally Posted by ringy9 View Post
    If you download through a playlist - no problem
    https://fastupload.io/8f67f3bc97048a1d
    Mar 2023
    Australia
    @ddll Not sure I understand what downloading a playlist entails in this sense, could you please elaborate
    Mar 2023
    Australia
    Hey guys still looking for a bit of help if anyone is inclined https://www.foxsports.com/replay/fmc-l7id4564yl2es26z
  6. Originally Posted by ringy9 View Post
    It's a bit of work until someone tells you an easier way. You can download the m3u8, remove the segments with ads (weirdly enough, the one that don't have ad in the filename are the ads haha), append the full url to the links with find and replace (parts are missing the https://foxvideo-sports.akamaized.net/) and give that to N_m3u8-RE to download from the local file.
    Here's a low res version
    https://www.swisstransfer.com/d/9410ddc0-82e4-4e32-ab34-aa09cf93718d
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
    Mar 2023
    Australia
    Thank you [ss]vegeta I will give that a try
    Mar 2023
    Australia
    @ [ss]vegeta I have tried to edit the m3u8 as suggested.
    https://files.videohelp.com/u/305113/6.m3u8.txt is the original (yes I know it is a text file, just so I could upload it)
    https://files.videohelp.com/u/305113/new.m3u8.txt (my edit)
    https://files.videohelp.com/u/305113/error.txt (error message)
    Hopefully you can point out my error
  9. Originally Posted by ringy9 View Post
    On a quick look, I think you missed just this:
    So, just use find and replace.
    Find
    /exp
    Replace with
    https://foxvideo-sports.akamaized.net/exp
    On a second look you also left out some #EXT-X-DISCONTINUITY which I'm not sure if they'll make problems.
    click click2
    Mar 2023
    Australia
    @ [ss]vegeta thanks so much for your help and clarification above. Worked perfectly. If only my VPN wasn't so slooooooooow
