The software that comes with your SDI card should be able to record the video signal.
Results 31 to 33 of 33
I don't see any problem for re-using worldwide accepted standard to amateur - hobbyist procedure - it is way more convenient to use well established methodology as you avoid entering to gray zone where some results may be unpredictable or too difficult to explain.
Test streams, patterns, signals will not corrupt anything so it is fine to try even sometimes bizarre things. -
The signal will be lowpass filtered by the anti-aliasing filter before it is sampled and A/D converted. The signal is "shaped" (distorted) by the characteristic (frequency response, impulse response ...) of that filter. A 'narrowband' signal (means upper frequency limited, controlled rise/fall times rather than abrupt step changes) wouldn't require this filter or would be less affected by it.
Also, for example PAL-B chroma bandwidth for broadcast is limited to 600kHz. Test signals have to comply accordingly. Excessive chroma or luma bandwith produces more chroma-luma interference (causing dotcrawl and rainbows) in composite video.
So it all depends what specific parameters one wants to analyze and test. A universal test signal doesn't exist. That's why there are so many (thousands) different test patterns and signals, some combining several tests in one image, many addressing the same issue. Adhering to standards or being manufacturer/tool specific.
Dynamic tests may also be of interest (checking brightness pumping, AGC action, transient behavior ....).Last edited by Sharc; 10th Nov 2024 at 17:21.
TBCs for VHS digital capture
By AndyO6322 in forum Capturing and VCRReplies: 31Last Post: 11th Feb 2024, 07:46 -
Quality comparison of VCRs by single test input
By LinuxGuy in forum Capturing and VCRReplies: 3Last Post: 30th Oct 2022, 12:41 -
What are in 2021 good capturing cards/devices from VCRs
By vlp_007 in forum Capturing and VCRReplies: 18Last Post: 6th Feb 2022, 04:38 -
New device, getting strange wavy / dot like patterns on the capture?
By Soundguy in forum Capturing and VCRReplies: 45Last Post: 3rd Jun 2021, 12:44 -
Question about color SMPTE color bars test patterns
By Videogamer555 in forum DVB / IPTVReplies: 11Last Post: 23rd Jan 2021, 05:38
